removing 60 pin connector from EEC
Old Sep 11, 2008 | 06:06 PM
95BroncoXLT5.8's Avatar
95BroncoXLT5.8
As you might guess from my handle, I have a 1995 Bronco with a 5.8 motor. Also, it is a California truck. I am trying to unplug the connector to the computer, just to check it for damage or anything that doesn't look right. I think I found it ok. There is a 10mm bolt in the middle of it. I tried backing the bolt out and pulling on the connector, but the bolt doesn't back all the way out and I don't want to force it. The connector doesn't seem to get loose at all. What am I doing wrong here?
Secondly, which computer do I have? EEC-V? or IV?
Thanks
Old Sep 11, 2008 | 06:32 PM
DJdemon6696's Avatar
DJdemon6696
EEC IV
you have to tunr that bolt a while.. its long.. i tought also that mine would not come off but its a long bolt.. keep turning it and keep trying to get it out
Old Sep 11, 2008 | 06:49 PM
95BroncoXLT5.8
Originally Posted by DJdemon6696
EEC IV
So the bolt comes all the way out? Then just pull the connector off?
Old Sep 11, 2008 | 07:40 PM
subford's Avatar
subford
No it does not come all the way out, it stays in the connector plug. It will back the connector plug out but if the plug gets a little cocked it will get hard. Just wiggle it back and forth as you back out the plug.
Old Sep 11, 2008 | 09:26 PM
95BroncoXLT5.8
Thank you.
grmtnmn
New Member Introductions
Aug 31, 2015 11:46 PM
FourXFord2
1978 - 1996 Big Bronco
16
Sep 2, 2014 11:20 AM
kevin206
15
Apr 15, 2014 04:30 PM
77_F150_4x4
13
Oct 15, 2012 05:49 PM
Stephen Tangalin
Jul 25, 1999 10:40 PM
