Sponsored by: Auxito
12v battery replacement---low idle?
Old Nov 21, 2000 | 05:25 PM
D's Avatar
D
Old Jan 24, 2001 | 08:19 AM
dgreene's Avatar
dgreene
had auto parts store install an optima/vertex battery 12 days ago. he failed to use the 9v codesaver. computer codes dumped...now engine idles too low (4-500 rpm) in "drive" when stopped. idle correct with no load on eng. thought low idle/code problem would correct itself. does anyone know a procedure that will reinstate proper codes???
Old Jan 24, 2001 | 01:24 PM
insect2's Avatar
insect2
It's my understanding that it takes some driving to get the codes back into the computer. I think its about 100 miles of driving so the computer understands your driving style.
Look in your owners manual and it should tell you.
You can get a "code saver" for next time at Pep Boys. It used a 9 volt battery you supply and insert into the cig. lighter and it will retain your codes and radio presets.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
