ESELIMINATOR regulator spring?
Old Sep 10, 2008 | 02:37 PM
whiteaddiction's Avatar
whiteaddiction
If I have the tranny out is it easy to get to the pressure regulator to replace the factory springs with the red ones from ESE. Or do I have to take the tranny apart to do that.
Old Sep 10, 2008 | 03:10 PM
tjbeggs's Avatar
tjbeggs
The spring is in the pump in the front of the trans. It would be relatively easy with the trans already out. Did you install the rest of the ESE yet? I just ordered mine this week.
Old Sep 10, 2008 | 03:53 PM
Gobstopper909's Avatar
Gobstopper909
sorry to but what is an eseliminator? is this the pump mod?
Old Sep 10, 2008 | 03:56 PM
tjbeggs's Avatar
tjbeggs
ESE Eliminator
It gets ride of the electronic pressure control system in teh E4OD and 4R100. It can be a trouble some system.
Old Sep 10, 2008 | 04:04 PM
secondarychaos's Avatar
secondarychaos
how hard would it be in place? that's one i've wanted to do.
Old Sep 10, 2008 | 04:24 PM
tjbeggs's Avatar
tjbeggs
You can do 95% of it with the trans in the truck just like a VB mod. They say in the directions that unless the trans is out don't worry about the Pump portion.
Old Sep 10, 2008 | 09:17 PM
oldbird1965's Avatar
oldbird1965
OK, what is the VB mod? At first I thought 'the cure' fixed my problem but ITS BACK! At light throttle just after TC lock my trans will shift to OD just for a half second then back to third gear. Same thing happened after the TW install, no problems for a while then ITS BACK! Will the eseliminator or VB or both help? Under heavier throttle it shifts fine. Thanks, Glenn
Old Sep 10, 2008 | 09:26 PM
whiteaddiction
Yes I have had my ese in for about a year now, Works great. only thing I don't like is the down shift from about 45 to 40 when slowing down my chip down shifts and the tc is locked, I feels like someone pushes the brakes and slows to about 35 without using the brakes. I put all the harder springs in, But have not changed the springs in the pressure regulator. Now I have my tranny out for a torque converter from racerX, And fixing my turbo Y pipe leak.
Do you know what exactly I have to do to find the pressure regulator springs?
Old Sep 10, 2008 | 09:28 PM
tjbeggs's Avatar
tjbeggs
no but PM MadVan or call Bill (RacerX) and they will be able to point you in the right direction.
Old Sep 11, 2008 | 12:00 PM
secondarychaos
ya, sounds like the chip needs to be coordinated with the ESE.
so what is the pump portion of the kit that would be missing?
Old Sep 11, 2008 | 12:04 PM
tjbeggs's Avatar
tjbeggs
Actually the chip really should not matter. The ESE takes the chip out of the equation for setting line pressure. So it really won't matter either as far as I know.
Old Sep 11, 2008 | 12:07 PM
secondarychaos
Does the line pressure control the shifts?
Old Sep 11, 2008 | 12:09 PM
tjbeggs's Avatar
tjbeggs
Line pressure controls (along with a few other things) how hard the shift is but not when it happens. that would still be up to the PCM/Chip
Old Sep 11, 2008 | 12:21 PM
Action4478's Avatar
Action4478
Is it only one time when the trans fl is cold ?...
Old Sep 11, 2008 | 01:25 PM
tjbeggs's Avatar
tjbeggs
Sorry Oldbird I missed your post but I think Rick is on to it. Sounds like the cold shift strategy.
