Bilstein Shock question
Old Sep 10, 2008 | 09:37 PM
DCSpecial's Avatar
DCSpecial
FWIW, on a mono tube nitrogen charged shock like the 5100 their orientation does not effect their operation.
As mentioned Bilstein's answer is to mount them so that the decal on them with the writing is facing the right way so you can read it.
Mounting boot down is more of a longevity thing as it doesn't allow dirt, grime, salt, water, etc.... to collect around the shaft seal. If they are boot/shaft up the body acts somewhat like a shelf and allows stuff to sit around the seal. But, on some shocks you have no choice but to mount them boot up. The boot keeps most stuff from ever getting in around the shaft anyway.
big poppa's Avatar
big poppa
Originally Posted by MikeSDK
Watch the boot against your exhaust pipe, though-- I have a 5in exhaust, and had to trim the shock boot back....it was melting on the pipe.
Great observation, thanks for sharing....
Old Sep 10, 2008 | 09:38 PM
DCSpecial's Avatar
DCSpecial
As for rears....if you were to swap the sleeve out of the bushing you could flip them.
The pin up top is a larger diameter than the bolt that goes through the rears. There is a sleeve that goes in the bushing on the bottom for the bolt....no sleeve up top since it won't fit.
Old Sep 10, 2008 | 09:45 PM
dvfd12's Avatar
dvfd12
Originally Posted by HH60FE
Rodger, bottoms up for boots down. OK I've beat that horse enough.
Old Sep 10, 2008 | 10:13 PM
suzuki_vinson's Avatar
suzuki_vinson
Ive been looking at some shocks. I need to replace the stockers. what is the best for our trucks?
Old Sep 10, 2008 | 10:18 PM
00Dave's Avatar
00Dave
Jerid, you will find, as I did, most folks prefer the Bilstiens. I put mine on about a month ago and man what a difference. Mine didn't have any instructions with them so I put them all boots down. I agree that this will possibly help with longevity. I also agree that it more than likely doesn't make a difference so whatever you prefer.
Old Sep 10, 2008 | 10:21 PM
jhand124's Avatar
jhand124
Jerid, I hate state the obvious but you are in a Bilstein thread. :-) They are our choice for shocks.
I haven't figured out how to do the simileys on my blackberry, I don't think it's possible.
Old Sep 11, 2008 | 12:56 AM
UP_There's Avatar
UP_There
it is possible to install the rear shocks with boots up on the 5100's. That's how mine is front and rear. Just looking at it.....it's wayyyy too close to the exhaust to do boot-down without melting it.
inspector747
Feb 11, 2015 02:08 PM
StilettoRed
Feb 27, 2010 04:17 PM
jac08f250
Jan 30, 2010 12:17 PM
elee3
Mar 17, 2009 06:16 PM
Steve_250
Jul 7, 2005 08:56 PM
