4.9 Header(s)
Old Sep 9, 2008 | 08:53 PM
95 F150 Dude's Avatar
95 F150 Dude
4.9 Header(s)
Guys,
Anyone have any experience with headers for a 4.9? Any pros or cons? I've been kicking around the idea for a couple of days. Who manufactures them?
Thanks, Scott
Old Sep 9, 2008 | 09:47 PM
DJdemon6696's Avatar
DJdemon6696
i tought all 4.9's came with headers from the factory
Old Sep 9, 2008 | 11:17 PM
85e150's Avatar
85e150
Uhh, not exactly.
EFI 4.9s have a header-looking pair of 3 into 1 manifolds. Pre EFI engines have a log style one piece exhaust manifold with a single exit.
A real long-tube header vs. the EFI manifolds is quite different.
Clifford and others sell headers.
Main question: Do you have smog inspection? 50 state approved headers may be harder to find.
See the 6 cylinder engine forums for info.
BTW, not a lot to be gained from the EFI motor via header alone. You need to keep the egr and other smog equipment so it will run right. (possible with the right header)
Anyway, check out the 6 forums for more.
Old Sep 10, 2008 | 12:54 AM
MatCat58's Avatar
MatCat58
Whoops I hit post at about 10 and it just went through
Old Sep 10, 2008 | 06:04 AM
95 F150 Dude
Thanks for the help. I do have to have annual emission inspections so leaving the smog equipment off is not an option. Also, my 95 is EFI equipped. I will check out the 6 cylinder forum and see how I can improve the performance. Thanks again.
Old Sep 10, 2008 | 07:22 AM
TexasGuy001's Avatar
TexasGuy001
I wouldn't bother with them on the 300. The OEM split manifold is just fine. The 4.9 does not move that much air and doesn't really need headers. Opening up the exaust from the manifold back is still a good idea though. The best thing to do for the big I6 is to keep it tuned up and the fluids and filters clean. Although it is a very good engine, its not designed for performance.
scottness2
May 27, 2014 06:10 PM
Morg89
Jan 20, 2013 10:15 PM
Hamstersbane
Apr 19, 2000 03:34 PM
Hamstersbane
Aug 17, 1999 05:59 PM
