Sponsored by: Real Truck
Nose Interchangability
Old Sep 9, 2008 | 01:57 PM
Exwildman's Avatar
Exwildman
Hello fellow Super Duty fans,
Does anyone know the interchangeability of the factory grilles, bumpers, and headlights between the previous generation (say 2001) model F250 and the last generation (say 2005-2006)?
I believe I have seen ’99-01 trucks with the ’05 headlights and even the ’05 grille fitted, but not the bumpers (the type with body colored plastic above the chrome, not the other way around as on the ’01).
Is this because it will not mount up? Honestly, the newer grilles and lights didn’t seem to look right with the older bumper, but it sure looks sleek with the whole package.
Thought it would give the old girl a fresh look if it simply bolted on.
Any feedback from any of you pro body guys would be appreciated.
Thanks.
Old Sep 9, 2008 | 02:30 PM
ReAX's Avatar
ReAX
The 05 grille is taller than the previous years. So to use the 05 grille, you need the 05 bumper or you have to cut the grille up. I like the bumper and the head lights, but the grille always seemed too big to me. I have the 05 lamps for mine when I find bulbs I want to use.
Old Sep 9, 2008 | 02:45 PM
tacoma9830's Avatar
tacoma9830
Thanks.
I did the full swap a couple years ago on my 2003 if you use the harness and other parts i posted back then it is 100% bolt on.
Hrere is the old post below with the info.
https://www.ford-trucks.com/forums/4...my-2003-a.html
Old Sep 9, 2008 | 03:11 PM
mwsF250's Avatar
mwsF250
So if I'm reading this right, I can put any "standard" headlights from SD's up through 2005 on my '99?
That would be nice... My '99 headlights are in bad shape. I'm sure I can find nicer from a later model. Which are believed to have the best lighting performance?
Old Sep 9, 2008 | 03:25 PM
tacoma9830's Avatar
tacoma9830
If you only use the 05-07 headlights you will have to cut up your 99 header panel for them to fit which alot of people have done with good results.
Old Sep 9, 2008 | 03:45 PM
ReAX's Avatar
ReAX
Or yes with a little work, you can fit 99-07 headlights. 99-04 are pretty much bolt on.
Old Sep 10, 2008 | 01:18 PM
Exwildman's Avatar
Exwildman
Grille/Bumper exchange
Hey Tacoma,
Many thanks for the info.
Glad to see someone else wastes time and money on these types of wacky things!
Thanks to all for the feedback.
TheDudeAbides
Ford Truck Parts for Sale
Oct 31, 2013 03:21 PM
Rosson03
Feb 26, 2011 03:32 PM
butch50
6.2L V8
Dec 6, 2010 12:49 PM
jpj64
1983 - 2012 Ranger & B-Series
25
May 24, 2010 08:58 PM
Technocrsr
Feb 17, 2007 09:13 AM
