Sponsored by: Real Truck
ball joint grease fitting
Old Sep 9, 2008 | 12:29 PM
woody367's Avatar
woody367
Has anyone been able to install the grease fitting in the upper ball joint of a F250 4x4 without the axle shaft snapping it off? Its a pain to take out the plug and put in a fitting just to greasre and then take it back out.
Old Sep 9, 2008 | 12:53 PM
superduty4x4's Avatar
superduty4x4
Mine's been in there a few months, so far so good but I have heard of them snapping off. The one I have is a 90* fitting and just barely clears.
Old Sep 9, 2008 | 01:10 PM
barnbridge's Avatar
barnbridge
I just had ball joints replaced at the dealer. The new upper ball joints have grease fittings already in them. It does look tight in there but so far they haven't broken off. How often should I grease them?
Old Sep 9, 2008 | 01:57 PM
skoveng's Avatar
skoveng
The same as Superduty4x4; just replace mine two weeks ago. I used a 90deg on the upper and it just clears; maybe 3/32. Close. I pointed it towards the rear.
Old Sep 9, 2008 | 02:41 PM
woody367's Avatar
woody367
Thank guys, I will try putting them in and see if I can screw them in enough to clea.
Old Sep 9, 2008 | 03:42 PM
350z's Avatar
350z
Thumbs up
I did mine in march of 04 , still good !
Old Sep 9, 2008 | 04:16 PM
ironmine's Avatar
ironmine
My NAPA ball joint came with both a grease fitting, and a plug fitting. I guess the idea was to switch fittings when you wanted to grease it.
I bought a 90* fitting, and put it to the bench grinder for a second. Works fine.
Old Sep 9, 2008 | 05:19 PM
superduty4x4
My ball joints came from Napa as well- only the 90* fitting no plug. Good idea on the grinder... I may try to take a file to mine for some added clearance.
Old Sep 11, 2008 | 01:19 PM
bens99f350's Avatar
bens99f350
I took mine to the bench grinder and created more clearance before I installed them, maybe ok without doing that but made me feel better.
4.9LOldFordTruck
Jan 20, 2016 04:38 PM
spinella
Apr 29, 2013 10:52 AM
fdude64
Nov 18, 2012 09:15 PM
Douglas DC-9
Jan 3, 2009 10:30 PM
GLF250
Mar 24, 2008 09:17 AM
