Sponsored by: Real Truck
Brush/grille guard help!!
Old Sep 8, 2008 | 10:51 PM
steve81's Avatar
steve81
Exclamation Brush/grille guard help!!
I just bought a used brush/grille guard from someone, but they didn't have the instructions on how to install it. I think it's a Manik that fits a 99-04 model. The problem I'm having is getting the brackets, that replaces/relocates the tow hooks, installed.
I took the bumper off, removed the tow hooks and added the brackets, but then the bumper wouldn't slide over the brackets. I then took the brackets off, put the bumper back on, but now I can't get to the bolt locations on the frame. ARGGHHH......can anyone help me out here?
Thanks,
Steve
Old Sep 8, 2008 | 11:14 PM
aldridgec's Avatar
aldridgec
I was pretty sure you could get to the bolts with the bumper on. But I'll have to look.
Old Sep 8, 2008 | 11:18 PM
steve81's Avatar
steve81
I tried, but couldn't get to them. Maybe I was doing something wrong?
Old Sep 9, 2008 | 12:00 AM
riggz's Avatar
riggz
Have you tried contacting Manik? Maybe they can help you out with a manual or guide.
Here is there contact info:
customerservice@manik.com
(626) 969-2180
Old Sep 9, 2008 | 10:17 AM
steve81's Avatar
steve81
yeah, I've send a couple of emails but no response. Thanks for their number, that'll be the next thing I do.
Old Sep 9, 2008 | 03:24 PM
high ho silver's Avatar
high ho silver
I'ver removed my tow hooks before without removing the bumper. Kinda PITA to get to though.
Old Sep 9, 2008 | 03:54 PM
steve81's Avatar
steve81
How did you do that?
Old Sep 11, 2008 | 04:06 PM
high ho silver
There are three bolts on each hook coming up from the bottom through the frame rail. I had to use an extension with a universal on the end because one of the bolts is kinda behind the end of the leaf spring mount. I used a lot of WD-40 before trying to break loose. They eventually came out after a good soaking.
