Red-headed step child
Old Sep 9, 2008 | 11:56 AM
DieselBeast01's Avatar
DieselBeast01
As I read through some of these post I often here that the 2001 model 7.3s have a few differences when compared to the others. They are often called the red-headed step child of the 7.3l diesels. Can anyone explain to me what is different about them and whether or not it is anything that I should be worried about?
Old Sep 9, 2008 | 12:00 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Simply put, they have the goofy mechanical diode in some of that year's transmissions, and thats the only year where it's debatable if the truck has PMRs or Forged rods.. However, ive been around here a while and ive never heard it referred to as that...???
Old Sep 9, 2008 | 12:04 PM
DieselBeast01
Other than pulling the engine apart, how would I know if has PMRs or Forged rods. I would like to assume that I will never reach the magical 400 hp mark, but just in case I ever do it would be nice to know if it does have PMRs or Forged rods.
Old Sep 9, 2008 | 12:05 PM
PowerstrokeJunkie
7.3 Inspection Hole for Powdered Metal Rod Determination
Old Sep 9, 2008 | 12:11 PM
DieselBeast01
I'm going to have to pull out this inspection hole plug and take a look at the rods.
Old Sep 9, 2008 | 12:44 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Thats what I did with mine. Pulled the plug and used a magnifying mirror to see the nuts. Took me 5 times hitting the starter to get a positive view. I do have forged rods. There is a few of us on here that have 01' trucks with forged rods. My build date was 8/00'. I have no problems with my trans as of right now, but I am putting a few more horses on it so,,,,,
Old Sep 9, 2008 | 12:59 PM
DieselBeast01
I just took a look at my build date and it is 9/00. Maybe I will end up being one of the lucky ones who has the forged rods...
Old Sep 9, 2008 | 01:51 PM
Ponyboychris's Avatar
Ponyboychris
Originally Posted by miller_feed
Thats what I did with mine. Pulled the plug and used a magnifying mirror to see the nuts....
Sorry, that's just funny stuff there...
Old Sep 9, 2008 | 02:04 PM
John311t's Avatar
John311t
Here is the easiest way to figure out which rods you have.
Here is the engine serial number break down for the forged and powdered connecting rods. Check you engine serial number on the valve cover build sticker or you need to look at the block where the oil cooler is bolted to it .
Start of production thru 1425746 are Forged Rods
1425747 thru 1440712 are Powdered Rods
1446713 thru 1498318 are Forged Rods
1498319 thru final production run are all powdered
Or you can break them then you know what you have-Ha Ha-Just kidding
The reason for the break in serial numbers is a "test" run to be sure there were not any issues with the powdered rods. Once the process was production tested the powered rod process was used until the end of production.
Old Sep 9, 2008 | 02:27 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
I made the red headed step child comment in the "which year to buy" thread... pmr's, dana 50, and diode problem. haha i didnt mean it it just sounded good at the time.
Old Sep 9, 2008 | 02:31 PM
PowerstrokeJunkie
Thats not always true too, as a few test motors had PMRs earlier than that.
Old Sep 9, 2008 | 03:12 PM
miller_feed
. Chris, the nuts aren't that big on the end of the rod.
Old Sep 9, 2008 | 03:15 PM
Neal 97 250's Avatar
Neal 97 250
What about 1440713 thru 1446712
I assume one of these is a typo but these #'s are left out.
Old Sep 9, 2008 | 03:20 PM
John311t's Avatar
John311t
So your saying that even though the break in the serial numbers where they went from Forged, to PMR, back to Forged then back to PMR's, that there was still some motors that had the wrong serial number from IH and had PMR's anyways in the first/second forged group?
Just a little confused, since I thought before there was a list, but it didn't show for the little test they performed which mislead a lot of people. Or has this list been used now for awhile and been proven wrong?
I would assume the 0 to be a typo, since the rest of them just go one right after the other.
Old Sep 9, 2008 | 06:44 PM
preppypyro's Avatar
preppypyro
So why did they not continue with the forged rods anyways?
