I've just bought a 1963 F100 short bed stepside with a blown engine. Literally a hole in the block so it's not rebuildable. The truck is in excellent shape and virtually rust free and I'm thinking I'd like to find a near original engine to put in it. I think it had a 262 originally. The VIN starts F10BR****** and the data plate says "132 HP 3600 RPM". Does that indicate a 262?
I'm starting to hunt the local boneyards and websites looking for a rebuildable engine and I want to be able to tell the difference between a 223 and a 262. After looking at a number of websites that deal with visually identifying a 262, here's my real question: does anybody know if there are block casting codes that definitively identify a 262? Thanks for your help!
The B is the VIN code for the 262, R is the San Jose plant, These engines have small aluminum ID tags commonly removed over the course of time and tossed for whatever reason...BUT if there is one and if it was in its original location, the tag would be bolted to the engine using the coil retaining bracket bolt...the tag will have the CID of the engine, its build date spproximate and revision level of the engine assembly.
Another member once reported that his 262 from a 1963 F100 has the number C1TE-6015-B cast into the side.
I have two 262 engines from 1964 F100s, and the same number, C4TE-6015-C , is cast into both blocks.
One sure way to identify a 262 block from a distance is to look at the strengthening ribs cast into the driver's side. There will be a horizontal ridge along the bottom of the block that the oil pan bolts into, and then two horizontal strenthening ribs running nearly the length of the block....one just below the dipstick, and another just above the dipstick. The 223 only has one of the strengthening ribs, and I believe it's located just below the dipstick.
Thank you folks! This all helps me. I'll let you know what I turn up. If there's anybody out there in the Seattle or western Washington area with an appropriate vintage 262 or 223 for sale, I'd like to talk to you.
If your Carb and exhaust is on the driver side of engine it is an 262. I have a running 262 from a Goverment special order 66 F100. Runs great with new overhaul before last own went to prision (life) and the milage is very low (20356) have Manny tranny if you need the too. I hope you are still checking thread. Steven @520-850-5920.
I know there is a slim chance that this will be seen by JimKoz, but I just wanted to thank him for the information. I was told that the engine was a 262, but based on your help it feels good to verify it! Hope you're well and staying safe during these crazy times. Working on my P400 (which I now know is NOT a Boyertown) keeps me busy and sane!!
Yes, old thread, but always an interesting subject. There were two versions of the 262, the heavy duty and the light duty. The light duty was new for '64, so it makes sense they will have a C4 casting number, while the heavy duty version will have the C1 casting number,
Wow...thank you for even more information! I knew the "TE" meant Truck Engine, but I didn't know C1 meant heavy duty. Thanks and stay safe...Kim
No that is not what they mean.
Lets break this down C1TE
C is the decade B= 50's C=60's D=70's etc
1 is the year
T is the vehicle/ Model A =full size B Bronco 70-73 Etc T = Truck light and medium duty
E is the engineering group A = Light Truck Engineering Division B = Body and Electrical Product Division C = Chassis D = Overseas Product Engineering E = Engine
So C1TE translates to is 1961, truck, engine engineering group.
