5.0 options
Old Sep 9, 2008 | 12:10 AM
Fifty4F100's Avatar
Fifty4F100
5.0 options
I saw many 5.0's in a pull-a-part junk yard I was in this weekend. I saw several that had what looked like low miles. But these had a very tall intake runner that I've never seen before. Would these engines work after taking this off and setting it up with a carb/intake manifold and perhaps a Pertronix ignition system? I also wonder if the automatic transmissions would work without the computer.
Old Sep 9, 2008 | 09:08 AM
classicranger's Avatar
classicranger
The engine can be set up with a carb and intake, but you will need to change the timing chain cover for and older one that has a place for the fuel pump, and add a fuel pump eccentric (this opperates the fuel pump) on front of the timing chain gear. If the car has an aod trans it is not electronic, so it can operate without the computer but it does have to have a tv(throttle valve) cable connected to the carb to operate.
For as ignition i would put a duraspark electronic ignition on it. I may have missed something but i'm sure someone else will chime in and help.
Old Sep 9, 2008 | 10:00 AM
MBDiagMan's Avatar
MBDiagMan
Interesting how you can tell the mileage of an engine by looking at it. That's a very good eye you have there.
Old Sep 9, 2008 | 07:16 PM
doug1222556's Avatar
doug1222556
Originally Posted by classicranger
The engine can be set up with a carb and intake, but you will need to change the timing chain cover for and older one that has a place for the fuel pump, and add a fuel pump eccentric (this opperates the fuel pump) on front of the timing chain gear. .
Only if he want's to use a mechanical fuel pump. I have a later model timing chain cover and, as far as I can tell, the only difference is that the fuel pump boss is closed off and the bolt holes not tapped. I plan on opening that one up and tapping the holes for a mechanical fuel pump. Then later on, I'll probably decide on an electric pump and I'll block the hole back off with a chrome cover plate!!! And I need to take someone with me that can judge those miles by eye when I go to the JY.
Old Sep 9, 2008 | 11:43 PM
LxMan1's Avatar
LxMan1
The tall intakes are probably from a pick-up truck. Flat tappet cams. pretty much a standard 5.0.
The Mustang and Mark VII's had the HO roller engines. 87-92 are the best with Forged pistons.
Old Sep 10, 2008 | 02:17 AM
Fifty4F100's Avatar
Fifty4F100
Since the engines where still in the trucks, I could look inside on the odometer. Some had the digit for 100000 miles. The older ones are a crap shoot since you don't know how many times they went around. Of course the new digital odometers you can't tell.
Old Sep 11, 2008 | 01:10 PM
s1120's Avatar
s1120
I would look first for a HO from a Mustang, or Lincon LSC, next I would look to a later truck 5.0. 87 and later trucks had the same heads as the GT's, and roller cams. GT's had hotter cams, and fordged pistons. A 94-95 truck 5.0 will have a slightly better cam then the earler truck motors.
Old Sep 11, 2008 | 07:35 PM
LxMan1's Avatar
LxMan1
87-92 were flat tappet on the trucks, I believe. I know 87-89 trucks were not roller.
Old Sep 11, 2008 | 08:36 PM
quaddriver's Avatar
quaddriver
the roller cam was not installed, but the block was roller capable. 86-up using stock ford parts
Old Sep 11, 2008 | 10:16 PM
Fifty4F100's Avatar
Fifty4F100
I went back today and found a 93 Mercury Cougar with a 5.0 HO. The gauge panel odometer read just over 111,000 miles. I saw that it has the double sump oil pan, so it should fit over my straight axle pretty well. I hear these are very good engines and I don't think a Cougar was ran that hard in those 111K miles. I really wish the leather buckets would fit in my truck.
What year did Ford start machining the engines to the tighter tolerances? I hope not for the 4.6 and 5.4 OHC's. I hear the new tighter engines can go 200K+ easy.
Old Sep 11, 2008 | 10:35 PM
doug1222556
Any motor can go 200k+, if cared for properly, or torn up in 30 if not!
ExitLeft
May 11, 2013 02:26 PM
mpgo4th
Dec 14, 2012 09:55 AM
INKAHOOTZ
May 26, 2009 04:48 PM
wilevel2
1978 - 1996 Big Bronco
15
Dec 5, 2006 01:26 PM
yellowjeep76
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Feb 9, 2004 12:12 PM
