5.0 HO differnt firing order ?
Old May 25, 2009 | 04:11 PM
INKAHOOTZ's Avatar
INKAHOOTZ
I have a 88 5.0 out of a 88 lx mustang . It does not have a intake or the fuel injection .(I removed it several years ago but sold the intake and FI . I believe it had the H.O. on the intake .) I saw somewhere that the H.O 5.0 has the same firing order as the 351 . How can I confirm that the 5.0 is a H.O and is the firing order the same as other 5.0 or the 351 ? Thanks rg
Old May 25, 2009 | 06:44 PM
70torino429's Avatar
70torino429
the ho does use the 351 firing order. if its from an 88 stang and is original then it would be an ho.
Old May 25, 2009 | 09:45 PM
410's Avatar
410
i was wondering bout that myself ive got a 86 302 out of a stang
Old May 25, 2009 | 11:34 PM
johnboy427's Avatar
johnboy427
It is just a difference in the cam, just turn it over and watch when the intake valve opens and use that as the firing order and see which one you have. If you plan on switching cams you can go with either one, I had a 289 that used 5.0HO firing order. I was told they did it to avoid loading up the front main bearing because 1 fired right before 4 and that was two in a row on one journal.
-Johnboy
Old May 26, 2009 | 04:48 PM
INKAHOOTZ's Avatar
INKAHOOTZ
Thanks , Ive got several motors and have ran into this issue , The info about the intake valve is simple enough .
telemaster444
Engine Swaps
Sep 16, 2016 08:55 AM
fordracer90
Jul 25, 2010 09:20 AM
hotroddually
Jun 29, 2010 12:30 PM
hotrodder72
13
Mar 5, 2010 04:55 PM
blindboyth
17
Oct 23, 2008 09:00 AM
