how do i know if my turbo is/going bad?
whats it mean if you have soot coming out of the clamp just before it goes into the downpipe? i was checking for my oil leak yesterday and noticed the soot. the turbo spools fine, fins all look good, no play in the shaft, etc. there was a little bit of oil blow by in the air filter box, but nothing too bad.
Instead of just tightening the clamp you may want to remove it completely and clean up the mating surfaces on the downpipe and turbo in case there is any carbon buildup there that's keeping it from sealing properly. The clamp can be a bitch to remove at times but just go ahead and pry it loose with a screwdriver or something.
yeah, its still got the stock airbox in it. i put a ton of sealant on the air filters top and bottom and so far it hasnt leaked any. i check it every oil change just to make sure. i didnt know there was a problem with them leaking until after i bought my k & n.
i havent tried to tighten the clamp yet. i just noticed the soot yesterday when i was degreasing the engine. ive got to pull the turbo to replace the o rings so ill clean it up when i do that.
After checking for exhaust leaks, I'd look into installing the 6637 mod, or an aftermarket cold air system. That will help out the turbo too, allowing more air into the engine. The stock air filter boxes on the 7.3 trucks are quite restrictive. The aftermarket air filter will also allow for more turbo sound, if you like that. The 6637 will allow for the most sound.
have you had any trouble out of your 6637? ive seen a lot of guys on here talking about having to take their air filter off to wash their truck, having to change back to the stock air filter when driving in the rain or going off road, etc. i go off road some with my job and it would be way too much trouble for me to have to swap my air box every time i have to go off road.
ill see if i can find the thread, it was one i was just looking at the other day. but one guy was saying he had to take his 6637 off every time he washed his truck and another said he had to put his stock box back on anytime he drove off road or in really wet areas. just sounded like too much hassle to me.
on a side note, i was looking at some downpipe threads on here and everyone cuts the pipe before removing it. can you not just unhook the clamp and pull the stock one out? ill be pulling the tranny out to rebuild it and put a new clutch in and id rather not spend time cutting something that will just slide out.
with the tranny out, the downpipe shouldn't be a problem. It's impossible to get the old one out when everything is together without hacking it to pieces. As for the 6637 filter, I've never pulled mine. Mind you I do need to wash the truck more often. I've run through heavy rains, foot think slush on the road (snow), never had any trouble with the filter getting wet.
#28
yeah, its still got the stock flattened dp on it. the truck is 100% stock. i was thinking about a 3" dp, 4" exhaust, TW chip, and possibly stage 1 injectors. its got 185k miles on it and id say its needing new injector o-rings, but im still trying to figure out the advantages/disadvantages of stage 1's. i dont want to kill my mileage when im running in stock setting on the chip, but id like to be able to get a little more out of the chip when running in tow/heavy tow mode.
#29
Stage one injectors aren't necessary for more power, the chip will do that on its own. There are different programs for mileage and towing. All do better than stock, it's just that you got to watch the temps on the exhaust, also known as EGT's, when you turn them up.
In no way am I trying to discourage you from getting the stage ones, I'm just saying you will get an increase in power with the stock ones. Stage ones will do more, that's for sure.
1976rustbucket
12-02-2023 06:28 PM
zx9ktm520fords
21
03-09-2010 11:06 PM
Tim Shultz
03-26-2008 10:11 AM
1997, 1999, bad, calibration, f250, ford, howdoiknowifmyturboisbad, iknow, kingsport, powerstroke, speedometer, tn, truck, turbo
