Offroad & 4x4
Dana 21 transfer case
Old Nov 7, 2002 | 04:47 PM
Goodold71's Avatar
Goodold71
Post Dana 21 transfer case
I have a dana 21 transfer case in my 71' f-100 4x4. It is mated to a np 435 manual transmission. The dana 21 is a single speed tcase. Does anyone know the ratio? And is this a good tcase for running in the mud? What other tcase options do I have for the np 435? Thanks JP
Old Nov 8, 2002 | 06:57 AM
72f100's Avatar
72f100
The Dana 21 is a 1:1 transfer. It has no low range. You should be alright in the mud especially if you have a fairly strong motor. I used to use 2nd gear most of the time for mud; you can get decent wheel speed w/o bogging the motor. You can use the granny gear as well but your wheel speed will be pretty low. The lack of a low range hurts you more on technical stuff like off camber climbing and rock crawling than in mud.
Old Nov 9, 2002 | 09:15 PM
electricmaniac2's Avatar
electricmaniac2
I figured with that trans/t-case combo, your granny 1st would be your low range...
Old Nov 10, 2002 | 12:41 PM
1970f2504x4's Avatar
1970f2504x4
Speaking of Dana Transfer cases, any opinions on the Dana 24 for 4 wheeling? I din't know much about the Dana 24 if it's good or bad..
James Kern
1970 F250 4x4
Old Nov 24, 2002 | 03:31 PM
proeliator's Avatar
proeliator
The '21 is a fairly weak transfer case, but you might as well run it untill you blow it. The Dana 24 is a strong, gear driven unit comparable to the venerable 205. Some guys shy away from the '24 because they aren't as familiar with them, but they are very similar to the 205 and just as strong. The 3/4 fords had the Dana 24s untill about '72 when they switched to the np205s. Both are great transfer cases, although the 205s are more common.
Old Nov 28, 2002 | 01:22 PM
alpo23's Avatar
alpo23
yeah, What Proeliater sayed.
Since you already have a married set-up with the D21 you won't find a married D24. only NP-205 came married behind a NP-435 in Ford. You need the adaptor and stub shaft. You will need to find out if the output shaft of the Np-435 with the D21 is the same as the output in a NP-435 with the NP-205. If not,you can find a '77 1/2-'79 F-150/F-250 or Fullsize '78/'79 Bronco. This will have a Np-435/Np-205 combo. Some may have a T-18 but most will Np-435. This will bolt up to your motor without any problems. Crossmember modification and driveshaft work should be the extent of the other mods.
Eric
Old Nov 28, 2002 | 03:36 PM
Ford_Six's Avatar
Ford_Six
yellow truck
19
Feb 6, 2015 09:03 AM
apachetech
Dec 30, 2014 03:04 PM
Ken2600
Jun 26, 2014 03:45 PM
mr. wackodog
1966 - 1977 Early Broncos
Feb 1, 2012 06:15 PM
1966flair
Offroad & 4x4
Aug 27, 2009 01:27 AM
