Tranny Woes
Old Sep 8, 2008 | 06:19 PM
Panthers65's Avatar
Panthers65
Tranny Woes
and no, it's not the kind your run into in the sketchy bar......
My transmission isn't shifting right. It costs fine and and drives fine under light load, but when ever I'm in OD and and try to speed up without dropping a gear or whenever I'm towing (empty single axle trailer) while in OD, it feels like my brakes are pulsating. I'm pretty sure it's not the brakes themselves (no light and it doesn't do it when I'm actually braking), but it actually slows the truck down, not just loose power. They only last about a quarter second, but they'll pulsate pretty fast (twice a second)
Any ideas?
Old Sep 8, 2008 | 07:25 PM
85e150's Avatar
85e150
Is this for the 2002 F150? Which engine?
Old Sep 8, 2008 | 07:34 PM
Panthers65's Avatar
Panthers65
yea, for the '02. 4.2L engine, 4R70W tranny.
It's not something that progressively got worse. Got dressed one night to head to a friends and it started doing it.
Changed the tranny filter and flushed the pan twice (4 quarts each time, only been about 10K since my last tranny flush) and it did not help any, so I'm guessing it's some little sensor or the TCM.
Old Sep 8, 2008 | 08:04 PM
jk080's Avatar
jk080
Transmission Rebuilder
My first thought is a engine miss.
I have these come into my shop all the time even from other shops thinking its the tranny.
Old Sep 8, 2008 | 08:11 PM
Panthers65's Avatar
Panthers65
engine idles find and I can sit it in the garage and race it with no miss
I actually feel the truck draw back then continue forward, almost like it just randomly kicks down a gear then jumps back very quickly
Also, I can slam down on the gas, kick out of OD, and it accelerates normally. really only does it when I'm about 1/2 way on the gas (speeding up from 40-50 while coasting)
Old Sep 8, 2008 | 08:23 PM
jk080's Avatar
jk080
You wont have a miss just revving the engine in park, there is no load on the engine.
In overdrive pulling a grade with the converter clutch applied is when the engine miss will be more noticeable.
Sometimes you can catch the miss by power braking in drive, don't let the tire spin and don't do it for long, it can generate a lot of heat.
Old Sep 8, 2008 | 08:32 PM
Panthers65's Avatar
Panthers65
a miss wouldn't throw a light or anything? I've got a OBD scanner and it's coming up with nothing, as is the scanner from Vatozone
I'm going to go give that parking brake thing a try, hope the neighbors don't mind..
Old Sep 8, 2008 | 08:55 PM
jk080's Avatar
jk080
Sure I have had them throw a code, but not all of the time, especially if they are intermittent.
Some misfire codes can be difficult to get with the basic scanner.
When you say "They only last about a quarter second, but they'll pulsate pretty fast (twice a second)" do you mean twice a second for only one second now and then, or for many seconds like running over the warning strip on the highway?
Old Sep 8, 2008 | 09:00 PM
Panthers65's Avatar
Panthers65
like running over a warning strip. They last for several seconds at a time, and pulsate very rapidly. I tried the power breaking thing and I felt it then too, looks like I'll be pulling some spark plugs tomorrow
Old Sep 8, 2008 | 09:29 PM
jk080's Avatar
jk080
Sorry for misunderstanding.
If it feels like the warning strip then I would lean more towards the torque converter shuddering in lock up, sorry.
The other problem is that you wont duplicate it sitting still power braking, that's not the converter!
Most of the time changing the fluid will fix the shudder, if not I would try some additive like shudder fix or lube guard. Sometimes replacing the converter is necessary.
Old Sep 8, 2008 | 10:00 PM
Panthers65's Avatar
Panthers65
well I was able to duplicate it by power braking, but it does feel almost like a drive-line vibe when it's doing it, only it actually pulls the truck back instead of just shake.
Old Sep 9, 2008 | 09:28 PM
Panthers65's Avatar
Panthers65
Thanks for the help, new plugs and I couldn't get it to skip again. Thanks.
Old Sep 10, 2008 | 06:55 AM
jk080's Avatar
jk080
Thats great!
Old Sep 14, 2008 | 12:53 AM
jason8225's Avatar
jason8225
You shouldn't be towing in OD!!
Maybe, just maybe, on a VERY flat surface, etc. but if you have a load of any considerable size you shouldn't be in OD when towing.
Old Sep 14, 2008 | 04:05 PM
Panthers65's Avatar
Panthers65
The trailer was empty when I was towing it, just a little single axle trailer, maybe 6-700 lbs.
I usually turn my OD off wen I'm towing my car until I hit the interstate
