Sponsored by: Auxito
gear ratio changes
Old Jan 26, 2001 | 07:14 AM
quinn's Avatar
quinn
gear ratio changes
On a 2001 E350 van if you increase the tire size from a LT245 to a LT295 how do they re adjust the speedometer and the tranny shift points ?
Old Jan 31, 2001 | 08:16 PM
majik's Avatar
majik
gear ratio changes
It's different for a dielel vs. gas engine. The diesel has a VSS (vehicle speed sensor) mounted on the transmission tailshaft that provides the vehicle speed signal for the PCM, speed control, etc. The gas engine uses the OSS (outputshaft speed sensor) on the transmission and it sent to the PCM which interprets the signal and sends it out to all necessary components. The gas engine requires a PCM update, the diesel is more involved.....
Old Feb 1, 2001 | 06:26 AM
quinn's Avatar
quinn
gear ratio changes
What's a PCM and how do you change it ??? When I asked the dealer he said "DUH"
Old Feb 1, 2001 | 06:07 PM
snowman's Avatar
snowman
gear ratio changes
19expy97
2004 - 2008 F150
34
Aug 14, 2011 10:36 AM
BPofMD
Maryland Chapter
709
Mar 1, 2011 05:16 AM
Lt_BigDaddy
Jun 7, 2002 10:32 PM
lt
May 8, 2001 06:59 PM
