1993 Ford F-250 5.8 351 Computer
Old Dec 28, 2010 | 09:27 PM
  #46
subford's Avatar
subford
OK as far as the PCM Computer goes just unplug it. Replace the fuse and if the fuse still opens when you turn on the key I would say you have a red wire shorted to ground someplace and the computer is not the problem.
Old Dec 29, 2010 | 08:52 AM
  #47
bigcrunch's Avatar
bigcrunch
Pull the plug from the firewall with the bolt thru it?
Old Dec 29, 2010 | 09:36 AM
  #48
subford's Avatar
subford
Yes that will take the PCM Computer out of the question.
If it blows when you turn on the key you will know the computer may be OK and you have problems elsewhere.
If the fuse does not blow when you turn on the key then the PCM computer would be bad.
Old Dec 29, 2010 | 11:11 AM
  #49
bigcrunch's Avatar
bigcrunch
TFI, distributor, ECM unplugged still poped fuse.. ????
Old Dec 29, 2010 | 01:03 PM
  #50
rla2005's Avatar
rla2005
The coil and radio suppression capacitor is also supplied with 12V from that fuse according to my EVTM manual. Bill has proven it to be wrong from time to time.
Old Dec 29, 2010 | 02:16 PM
  #51
subford's Avatar
subford
Sorry mine does not say that, here is what mine says:
The RED wire 361 is your problem and here is where it goes:
Old Dec 29, 2010 | 03:19 PM
  #52
bigcrunch's Avatar
bigcrunch
wire 361 to the EGR controls solenoid?
mine is a 5 spd manual trans dif from EOD?
I'll unplug the coil and radio suppression also and try it again.
Old Dec 29, 2010 | 03:43 PM
  #53
subford's Avatar
subford
The 361 wire does go to the EGR and AIR solenoids.
You just do not look at the part of the diagram that says E4OD.
The coil and radio capacitor have nothing to do with fuse "I", look at the diagram. They are controlled by fuse "U".
Old Dec 29, 2010 | 04:08 PM
  #54
rla2005's Avatar
rla2005
Then I guess I misunderstood which fuse was blowing. The photo Bill posted previous had Fuse "U" highlighted as "PCM Relay Coil Fuse" Now I see in your post you mentioned Fuse "I". Which one is opening when turning the key on?
Old Dec 29, 2010 | 04:19 PM
  #55
bigcrunch's Avatar
bigcrunch
Here is what I found I unplugged everything, coil, ECM, distributor, radio suppressor, TFI, throttle position sensor, EGR plug.
still popped fuse I
I took a look at the passenger side of the engine and I notice on fuel injector for cylinder 3 has the insulator pushed out the top of the electrical plug and soaked in gasoline. I remove the plug from injector and more fuel oozes out.
So I plug everything else back in except for injector #3. And no popped MAXI fuse. I hear the fuel pump kick on and more fuel comes out the solenoid plug of the injector.
Looks like the fuel was shorting it out.
So now I need to change injectors all of them since I do not trust the brand that is in there with this issue. Painful to do??
Old Dec 29, 2010 | 04:36 PM
  #56
bigcrunch's Avatar
bigcrunch
will it hurt it to drive it 300' with the one injector unplugged?
Old Dec 29, 2010 | 04:46 PM
  #57
subford's Avatar
subford
No it will run with one unplugged.
But do not get a spark around gas setting on the engine as it can burn the truck.
Old Dec 29, 2010 | 07:38 PM
  #58
bigcrunch's Avatar
bigcrunch
ok all good info here and is much appreciated, any tips on changing the injectors?
Old Jul 21, 2012 | 07:25 AM
  #59
Nick Seastrunk's Avatar
Nick Seastrunk
having trouble with my 1992 f150 with a 5.8 and shock trans
Lime I said my 92 5.8 shock auto trans and the problem is that when its cold it'll run good but a little rough but then it'll go alway and then it'll act like it not getting fuel when its hot it'll get even worse, I check the relays for the pumps ad they're good so where do I look next and how do I test the main computer or weres the main fuse for it is??
Old Jul 21, 2012 | 08:14 AM
  #60
subford's Avatar
subford
Nick Seastrunk,
First off you need to start a new thread with your problem.
If it is running at all the fuse for the computer is OK.
You need to run the Key On Engine Off (KOEO) self test and then next you need to check to see what codes you have in the Computer Memory (CM).
IF you get a 111 or 11 with the KOEO test then you need to run and only then the Key On Engine Run (KOER) self test.
More information on the self-test:
Fuel Injection Technical Library » How To Run a Self-Test
Post these codes and we will see what may be wrong with your truck.
lawdawg79
Aug 12, 2015 06:25 PM
SOLOLUCKY
Mar 5, 2015 06:58 AM
phroldschool
Jan 31, 2015 03:17 PM
towsrus
Oct 28, 2011 11:34 AM
Trucker51
Computer Chips & Tuners
Dec 12, 2008 06:54 PM
