Sponsored by: Real Truck
Backup sensor switch problem...
Old Sep 8, 2008 | 07:20 AM
dfooch's Avatar
dfooch
Have backup sensors on my SD in my signature. When I put the truck in reverse, the audible alarm doesnt activate and the off light illuminates on the button to disable the audible alarm. When I mash the button while it is in reverse, the light goes off, but the audible alarm still does not activate. Seems to be an obvious problem with the button/switch. Has anyone had this problem before? If so, what was the cause and remedy; aside from replacing the button/switch?
Thanks
Dave
Old Sep 8, 2008 | 09:03 AM
skoveng's Avatar
skoveng
Had the same problem on my wife's Ex. It turned out to be one of the sensors in the rear bumper. Funny thing is that when I hooked up the scan tool it did not show a problem in the system. Took it to the dealer and they replaced the sensor...no problem there after. It wasn't cheap; about $120 for the sensor + an hour labor.
Old Sep 8, 2008 | 06:05 PM
dfooch's Avatar
dfooch
WOW...what a pain in the ****. I bought an extended warranty through my bank when I bought it that is suppose to cover "everything". I will put it to the test this week. Thanks for the info though.
Old Sep 8, 2008 | 10:09 PM
fnmoving's Avatar
fnmoving
I am having the same problem with my 05 f-350. Just started happening out of the blue. If you don't mind post any info you find out. Thanks
Yep
6.7L Power Stroke Diesel
24
Feb 19, 2017 05:55 PM
Bradmclendon
Sep 5, 2016 04:32 AM
Laserman
Sep 14, 2015 05:54 PM
jnunez
Jan 26, 2007 12:43 PM
Glazeddonut
2004 - 2008 F150
Feb 4, 2005 10:20 AM
