Disable the Panic Alarm???
Old Feb 3, 2005 | 11:14 PM
Glazeddonut's Avatar
Glazeddonut
Question Disable the Panic Alarm???
Does anyone know an easy way to disable the audible alarm on an '04 F-150? I'm not a big believer in car alarms, and have the secure key and ignition disabler anyway. It's too easy to hit the 'panic' button on my keychain by accident, and I'm sick of setting the thing off in my driveway.
Old Feb 4, 2005 | 06:21 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 4, 2005 | 09:47 AM
WEB's Avatar
WEB
I am sooooo with you on the panic alarm.
I seem to hit the thing every once and awhile. I leave the house at 5 am and twice I have had the key in my hand and put my hand down on the seat to climb in and sure enough the thing is going nuts. I hope some one can come up with a disable but short of opening up the pod and disconnecting the wire to that button I think we are stuck with it.
Old Feb 4, 2005 | 10:20 AM
PC Poppy's Avatar
PC Poppy
Use some glue on the button so that it can't be depressed. The type of glue is your choice - permanent or temporary. Silicone might make it still useable but you may need to depress it a bit harder.
smcnaughton
Apr 2, 2022 02:21 PM
pickerdd
Sep 14, 2017 04:27 PM
JWA
May 21, 2012 05:49 AM
dragula
Jan 24, 2005 08:23 PM
StuartClark
1997 - 2003 F150
Dec 3, 2003 01:55 PM
