Help with rear-end code
Old Sep 7, 2008 | 01:07 AM
70mazie's Avatar
70mazie
I have a 70 Custom with a 300 CID and a 4 speed. The rear end code is
WDM-T 9JE
3.50 8 7 311A
I assume that the 3.50 is the ratio. What would be the next step higher that might give me a better range with the 4 speed?
Thanks
Old Sep 7, 2008 | 01:54 AM
85e150's Avatar
85e150
First is real low in your trans, right?
3.00 or the 2.75(approx) gears will make a pretty big diff and you'll still be able to launch with your low first gear.
You can plug in your numbers here to see the results; you need your tire diameter.
Novak Conversions - Gearing & Gearing Math for Jeeps
Old Sep 7, 2008 | 04:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 70mazie
I have a 70 Custom with a 300 CID and a 4 speed. The rear end code is WDM-T 9JE 3.50 8 7 311A
Thanks
WDM-T = Ford 9" (8.7 - 8 3/4" Ring Gear) / 3.50-1 / non Limited Slip / Slim Line (Tapered Roller) Differential Bearings / Large Axle Bearings / 3300 lb. Rear Axle Capacity.
Old Sep 7, 2008 | 01:57 PM
70mazie's Avatar
70mazie
the first gear is very low. Thanks for the input.
Shane Carruth
Jan 1, 2015 02:16 AM
Red69
Aug 30, 2014 01:02 PM
wagonerkl
Dec 18, 2009 07:42 AM
rockfordboy
Jan 9, 2004 07:29 AM
forwardcontrol
Feb 27, 2002 07:35 AM
