Aerostar Ford Aerostar
Air bag code 23
Old Nov 20, 2003 | 01:25 PM
Xanderificus's Avatar
Xanderificus
Question Air bag code 23
New guy here. I came looking for advice on how to get my non-mechanical hands closer to my spark plugs and found that I might be able to get an answer to another question:
I know someone(s) has found an Air Bag Code Table from somewhere and I'm wondering if anyone can tell me what code 23 is (and 32, just in case )
It started up a week or so ago and -seemed- to coincide with the death of my horn.
Any input is greatly appreciated.
Xander
Old Nov 21, 2003 | 04:37 AM
rlmdad's Avatar
rlmdad
Air Bag Code 23 = Right cowl side panel front air bag sensor circuit input feed/return circuit open
Air Bag Code 32 = Driver side air bag module high resistence or open
Caution, I found these codes while searching other sites for info on my 92 Aerostar 3.0L 2wd A/C auto trans. Can't remember the site but be aware codes may not be for your year. At least you have a place to start.
Currently, my system is sending a code 32 which could be simply a disconnected wire in the steering column..I've read somewhere that adjusting the adjustable steering wheel can cause the connector for both the winshield washer and/or the air bag to come loose. I guess it could also cause the horn connector to loosen as well, although that wasn't mentioned.
I checked my owner's manual and the Air Bag system and the horn are on two separate fuses, so that's not the problem. That is unless you have two fuses blown
I haven't had time to tear into mine as my wife drives the car every day, even on weekends...Also, I'm a little leery of messing with the air bag system after reading all the cautions.
Let me know if this info helps.
Ron
Old Nov 21, 2003 | 09:44 AM
Xanderificus
Good to know. While not a 'good thing', it's at least something that I won't worry about while driving alone. My old car used to use the engine light for all kinds of diagnostic information so I was concerned that the air bag light was trying to tell me something more pressing, like "Beware Imminent Engine Explosion"
Yup, I checked last night. It's "23". Thanks, though.
Sounds like we have pretty similar models, expect mine is a '93.
Then again, maybe not an exact match ... my column doesn't adjust.
With "Myron" (my van), anything is possible.
As would I be, without reading the cautions.
If a 'Luddite' is a non-technological person, what would a non-mechanical person like me?
Sure hasn't hurt. Thanks again.
Ron
Xander
Old Nov 21, 2003 | 11:17 PM
rlmdad's Avatar
rlmdad
Xander,
As it's a code 23 have you checked the wiring to the sensor? Could be that the connection has come off thereby opening the circuit. I'd hate for you to be driving along and have the air bag deploy because the connector wires shorted to ground. Besides, it's really annoying to have that air bag light flashing all the time, especially at night.
Ron
Old Nov 27, 2003 | 04:05 PM
b2trausch's Avatar
b2trausch
The fact that your horn died at the same time indicates to me that it could be the clock spring located in the steering column. The clock spring is actually a coil of copper flat wire that makes all the connections to the horn, cruise control, and air bag. I've experienced the same problem on my 95, and this was the fix. New they're about $95. There are some specific procedures that must be followed when removing the air bag. Make sure that you disconnect the battery, and wait at least 10 minutes before removing the air bag assy. The clock spring can be checked with an ohm meter to make sure that this is the problem.
Gene W
Oct 29, 2013 10:03 AM
95F150SuperCab
Dec 30, 2011 05:49 PM
ehgeeray
Jun 6, 2010 07:34 PM
AlexTG
1978 - 1996 Big Bronco
Nov 22, 2005 05:45 PM
Darth Baiter
1983 - 2012 Ranger & B-Series
Dec 8, 2003 08:49 PM
