Offroad & 4x4
HOT HUBS!
Old Dec 22, 2002 | 05:16 PM
wille3r's Avatar
wille3r
HOT HUBS!
I would almost bet a paycheck that it is the brake caliper. My passgr. side front was acting the same way yours is. A brake caliper sticking will burn up bearings. If I were you I would change the calipers. They`re not that expensive. Mine were dual piston and only cost about $20. apiece. Good luck. One other thing, make sure your races are good when you change your bearings. And do a follow up on your bearings after driving on them for a couple of weeks. Make sure the slack is out of them!!
`82 F-250 Custom** 4x4 ** 351W ** 39.5--15x16.5** SS- TSL`s ** 6" Lift ** Granny 4-speed**** If you can`t run with the BIG DOGS , stay on the porch!!!
Old Dec 22, 2002 | 11:50 PM
blownbronco's Avatar
blownbronco
HOT HUBS!
Is it okay if they get warm to hot after 2-3 hours of using 4X4??!:-X12
Old Dec 23, 2002 | 12:33 AM
Racerguy's Avatar
Racerguy
HOT HUBS!
TchTchr
Feb 21, 2014 04:24 PM
PSDlongbox
Mar 2, 2013 11:30 AM
Fishin76
Dec 7, 2010 10:53 PM
RhinoScores
1978 - 1996 Big Bronco
Sep 23, 2006 09:29 PM
dinty01
Apr 2, 2006 08:50 PM
