Sponsored by: Real Truck
Keyless Entry
Old Sep 6, 2008 | 02:25 PM
bass-n-fire's Avatar
bass-n-fire
Keyless Entry
I have a 97 F350 4X4 Powerstroke. How can I find out if this truck came factory with keyless entry? I have a friend that has a 96 model and his has it. If not, how can I get one?
Old Sep 6, 2008 | 06:48 PM
bubbla's Avatar
bubbla
If your truck came with keyless entry, I think you'd have a keypad on the driver's door.
The owner's manual shows you how to set up your own personal code. I believe tehre's also a preset factory code that can't be changed.
I'm sure this is a system you can also get aftermarket.
hth!
Old Sep 6, 2008 | 07:09 PM
ReAX's Avatar
ReAX
Yes, if you have power doors, doing an alarm system to gain to keyless is a very nice option. You can even go big and get a remote start alarm, that can lock/unlock the doors, start the engine and alert you when there is an intrusion.
The alarms/RS can be installed regardless of factory keyless and will give you more options.
Old Sep 8, 2008 | 11:01 AM
Beerstalker's Avatar
Beerstalker
A 97 F350 definitely wouldn't have the keypad on the doors. It wasn't offered until after the Super Duty came out. It wasn't standard on anything until the 2005 model year it became standard on Lariat and above (Harley, King Ranch, etc.).
You best bet would probably be to contact Ford and try to get a build sheet for your truck to see if it came with keyless entry.
Old Sep 10, 2008 | 08:03 AM
bass-n-fire
How would I go about getting a build sheet? I was speaking of the keyless entry using a remote, like the ones for alarms. As I stated, a friend of mine has a 96 and his came from the factory with keyless entry.
Old Sep 10, 2008 | 10:50 AM
Beerstalker
Do a search in here. Someone has posted a phone number or email address of a contact at Ford that will send them out. Edit/ Just found a post with it.
https://www.ford-trucks.com/forums/7...ml#post6532213
Also you might want to check in this forum as it is a little more geared toward your truck. They need to update the forum name to include '97 F250 and F350 Heavy duty trucks (the 97 F150 and F250 Light Duty are completely different trucks from the 97 F250 and F350 Heavy Duty).
1987 - 1996 F150 And Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Old Sep 10, 2008 | 11:44 AM
bass-n-fire
Thank you Beerstalker. Just sent an email requestion the build sheet.
