Offroad & 4x4
4WD clunking
Old Dec 26, 2002 | 08:54 AM
Havran's Avatar
Havran
4WD clunking
The other day I engaged my 4WD and I started to here an intermittent clunk from the front end. I brought the truck home and left it it 4WD and jacked up all four corners. I started the truck and all four wheels turned. When I slowed down and braked the front came out of 4WD. The front driveshaft continued to turn. I serviced the front hubs not to long ago and they appeared fine and 4WD worked ok until now. Is it time to deep six the auto hubs? This is a '96 F150.
Old Dec 26, 2002 | 10:14 AM
pbrstreetg's Avatar
pbrstreetg
4WD clunking
Hi-
I think what you said- ditch the auto hubs- is a good idea.
While you could fix them as they are, why bother. It could cost you even more. If you buy Warns they will be way better than any factory auto hub could wish and you'll never have to guess if your in 4x again.
Old Dec 26, 2002 | 11:54 AM
steve83's Avatar
steve83
4WD clunking
I agree. It doesn't matter how you baby autos - they can break anytime with no warning. I use MileMarkers HEAVILY with no problems and they're a little cheaper than Warns with the same LLT warranty.
Old Dec 26, 2002 | 09:35 PM
Starratt04's Avatar
Starratt04
4WD clunking
what you need is new hubs.i had the same problem on my ranger and some mechanic tried to tell me i need new axle or cv joints or something. but i know it was the hubs. just to make sure i when by 4 wheel parts and talked to the mechanic up there who worked for ford for 10 years and as soon as he heard it he said i need new hubs. next i went to ford to get new auto hubs. ford wanted to charge $635 for 2 new auto hubs i said forget that. so i went back to 4 wheel parts and i got 2 warn locking hubs with the install kit for $202. these hubs are way better than any auto hub. it was well worth the money.
Old Dec 26, 2002 | 11:03 PM
steve83's Avatar
steve83
4WD clunking
[updated:LAST EDITED ON 27-Dec-02 AT 00:04 AM (EST)]$202 would be a massive rip-off if it was for a 1/2-ton truck. A set of LLT hubs for a Bronco/F-150 shouldn't cost more than $100, but my MMs were only $60. The "install kit" (really just a set of bearing nuts) can be had for $12 plus a little shipping. The grand total for parts should be under $100.
Old Dec 27, 2002 | 11:38 AM
Starratt04's Avatar
Starratt04
4WD clunking
wht the heck is LLT or MM ive never heard of those. warn is on of the top brands for hubs and winches you can possibly buy
Old Dec 27, 2002 | 12:00 PM
steve83's Avatar
steve83
4WD clunking
Limited LifeTime (warranty)
MileMarker (also a top name in winches & hub locks)
Old Dec 27, 2002 | 05:24 PM
steve83's Avatar
steve83
4WD clunking
dutchnichols
Sep 26, 2014 09:29 PM
5.0 Heaven
1978 - 1996 Big Bronco
Feb 12, 2013 07:21 AM
MDSuperDuty
Dec 5, 2011 07:37 AM
BroncoPimp94
Feb 9, 2010 06:45 PM
jracer01
Mar 5, 2005 10:02 PM
