grille swap
Old Sep 5, 2008 | 09:54 PM
BigDave74's Avatar
BigDave74
grille swap
will a 70 grill fit in a 69, mine is beat up bad and i prefer the looks of the 70 over the 69, not to mention i cant find a good one cheap, what all would have to be changed over, headlight doors, inner and outer grille shell... help is appreciated
Old Sep 15, 2008 | 04:00 PM
matejcekautoworks's Avatar
matejcekautoworks
the grille shell, head light covers, thats really about it, pretty easy to do
Old Sep 16, 2008 | 11:49 PM
scottfreeman's Avatar
scottfreeman
Lots and lots of bolts running from the inside out. Wear safety glasses and pre-soak all of the bolts you will be removing with WD 40. When the bolts bind up in the clips then can pretty much destroy a cherry grille. Just my 2 bits from experience.
Old Sep 17, 2008 | 11:19 AM
trick1911's Avatar
trick1911
In my experance you need the lower valance, because the way the turn siginal is mounted and all that matejcekautoworks said. good luck. trick1911
Old Sep 17, 2008 | 11:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967/69 parklamps are different than 1970/72's.
1967/69's mount into the grille, below the headlamps.
1970/72 parklamps mount between the stone shield (valance) and the grille.
So, if you are using a 1970/72 grille in a 1967/69, you'll also need both parklamps, which are right/left specific.
There are dozens of threads on this subject.
Strongbad
13
Apr 2, 2010 12:25 PM
SAlexander
May 15, 2008 12:09 PM
George diB
Aug 9, 2006 06:56 PM
TheImpaler
27
Jul 21, 2003 09:58 AM
GA69Ranger
Apr 27, 2002 10:55 PM
