Any body ever run in to this problem, I have f 250 5.4 2004. Heated O2 sensor not ready O2 sensor not ready. this is for NY state emissions inspection. I have driven over 500 miles since checking & they are still not ready, 1 of the 2 must become ready for inspection. there are no codes and I have not cleared computer. no check engine light, I have done a complete diagnostic scan checking & monitoring O2 sensors they are functioning correctly. battery was disconnected about 700 miles ago for a while but thats it.
Try a vacuum check. The heater circuit can show out of range when you have a vacuum leak. After that, your going to have run the wires looking for cuts, shorts, ect.
Are you sure they are doing the proper emissions test for your vehicle? The '04 f250 superduty shouldn't be getting an OBD2 emissions test cause an 04 is not obd2. Ask your inspector.
My 03 F-250 5.4L has had those 2 monitors not ready for the past 2 years. Your inspector has to enter the truck as a heavy duty (over 8800 pounds) vehicle, and then the inspection computer will ask for a sniff test instead of an OBD II test. That's what I had to do.
OBD2 communications compatible only for over 8500lbs gas vehicles. Just like the Diesels communicate over the OBD2 bus, but they don't follow OBD2 protocols. There are all sorts of SAE standards that define the two but I don't care to recall what they are.
I've never owned over 8500 lb gas vehicle in MD, I wonder how they do it here, if at all?
Step #1 is to determine the GVW. The number 8500# is what comes to memory as the dividing line between LD and HD and the corresponding testing standards that are to be followed.
The problem is, basically, our trucks were not required to have an EGR or O2 sensor after the catalytic converter, NOR some of the other emissions monitors like heated O2 monitor. It's basically called "OBD-I" with an OBD-II interface.
Could this also be true for '00 F350 V8 5.4L in California? I've replaced both O2 sensors, the PCM and the coolant thermostat with significant mileage between each replacement and the monitors won't set.
9900. When it weighed for testing though it was 6000, can the smogger bypass in Ca?
It passed two years ago at the same shop so I would think the guy would be aware of this but I'm at a loss, and the loss somehow just keeps growing. Thanks KREWAT
It sounds exactly like what I used to go through here in New York. Some shops would try to hook up to the computer and scan it as an OBD-II compliant vehicle, when it's NOT.
Check your underhood emissions sticker. It may (or may not) say OBD-II compliant. If it doesn't say it, or it says OBD-I compliant, point that out to the inspector.
Here in New York, they go either by the weight of the commercial registration (the GVWR) or the weight on the passenger registration which is unladen weight. I have a passenger-car registration, so the guy looks at it being 5600 lbs and thinks it should be OBD-II compliant. Trick is, it's an 8800lbs GVWR, which is over 8500, which means that it doesn't HAVE to be OBD-II compliant. To get it passed correctly, the inspector has to manually enter the "weight code" as over 8500lbs, and then it says "do an idle sniffer test" instead of plugging into the OBD-II port.
I believe your inspector needs to realize it's over 8500lbs, or some other magic number, and then they will pass you the right way.
I talked to two Smoggers and they both said basically the same things, they have to complete self tests regardless of weight.
California should have a DMV call-in number for emissions. New York does, which is who I talked to, and they basically told me that the inspector had to change the weight class.
You can check smog records, based on VIN and license plate #. I'd look at that and see what you can find out, if it says anything about what type of inspection it got when it passed before.
