painless wiring????
Old Sep 5, 2008 | 09:02 PM
Kusto's Avatar
Kusto
Originally Posted by bobbytnm
Julie,
Here is a decent write up on installing a wiring harness in an old truck. The guys that wrote it up was installing a harness in an old Chevy but the basic concepts are all the same and its good information;
1954 Chevy Pickup | Rewire Project - Page 1
Nice job on the diagrams! That's good info
Bobby
Bobby, thanks for the link. A 10 day wiring install sounds just about my speed. I too am looking at the EZ or Painless 21 circuit wiring harness as I am going with an electric fan, power windows, interior lighting, power seats and ground effects lighting so I think I will easily use up the extra circuits.
Old Sep 5, 2008 | 09:32 PM
theGman's Avatar
theGman
Dittos on the EZ 21 circuit kit; decent price.
Old Sep 5, 2008 | 11:20 PM
RUSTY50F1's Avatar
RUSTY50F1
I just ordered a ez-21 yesterday for my sons 88 4x4. It cost me $174.00 with shipping. I bought one last year for my 50f1 for $150.00. Well worth every cent.
Old Sep 6, 2008 | 12:15 AM
Nighte51's Avatar
Nighte51
I purchased a Painless kit for my CJ7 and it was pretty easy and straight forward to install. Other than a few problems routing around things and a couple of user error problems (ie- misreading the instructions and hooking a couple of wires to the wrong terminal) it was very easy to install and took no time at all. I didn't find any problems with it other than the fairly high price, but in my opinion, it was worth it for the ease of installation. I plan to purchase a Painless kit for my 51 when I get ready to wire it up.
That's my 2 cents....
Old Sep 8, 2008 | 08:39 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Kusto,
I wired my truck in a weekend. Of course I didn't have to mess with carpeting and interior panels. The biggest issues I had were deciding where and how to mount the fuse block and where to route the wires. I ended up fabbing a bracket that mounted to my custom hanging pedal assy (I didn't want to drill any holes in my firewall). The original location to run the wiring harness through the firewall is on the upper left. I didn't want that huge unsightly mess. I ended up running my wiring harness out through the passenger side toe board just to the right of the tranny hump (there was an existing hole...and the wires came out right near my starter for easy hook up) The added benefit of this was that I could keep the harness low and bring the necessary wire up and mostly hidden to the alternator and distributor.
I think I laid out and routed the wires 3 or 4 times before I decided how I was actually going to route the harness. My advice is to not make any connection at all until you are happy with the routing. Get everything where you want it and then start making the terminations.
Also...I don't like the look of the crimp connectors, so what I would do is to remove the plastic sleeve from the crimp connector (easy to do with a small punch) then I would solder it on the wire and use heat shrink tubing to insulate it (put the heat shrink on before soldering....lol). This make much cleaner and longer lasting connections.
Bobby
Old Sep 8, 2008 | 03:47 PM
Kusto's Avatar
Kusto
Bobby
Good points there Bobby. I too have been fooled by the shrink tube before.
Old Sep 8, 2008 | 05:31 PM
TxF100's Avatar
TxF100
I did the same on a CJ7 I restored. I went one step further before adding the shrink tube, I put a small amount of dielectric grease on the terminal to prevent any corrosion on anything that could be exposed to water.
Kusto,
Bobby
Old Sep 8, 2008 | 06:31 PM
edsf100's Avatar
edsf100
If I hadn't used the Painless Fuse Block I would have used the EZ Wire. I Got the fuse block for a low price and just purchased the wiring and did some other cool stuff with LEDs and relays that I wanted to do. The one thing I have to agree is by doing the wiring yourself you learn so much more about your truck. I took my time and enjoyed every minute of the process. FTE had some great info and threads to get answers.
Crash F250
17
Oct 22, 2020 08:12 PM
Ranger_bound
Feb 21, 2015 11:28 AM
Ortarheel
Aug 19, 2013 04:47 PM
Cooter55
41
Jun 2, 2011 05:26 AM
grandaddy's66
19
Jan 28, 2004 07:45 PM
