91 350 wont start???
Old Sep 3, 2008 | 06:41 PM
foolforfords's Avatar
foolforfords
okay, heres the symptoms, truck turns over , has spark, had the ignition mod checked tonight its still good so the parts guy says.when cranking on i can smell gas , but i dont here the fuel pump cycling.thats on either tank.put a new fuel relay on and still no go,I dont have a pressure gauge to check fuel pressure. need to get this truck running soon any ideas...by the way its a 460 thanks FFF
Old Sep 3, 2008 | 07:25 PM
subford's Avatar
subford
Try resetting the Inertia Fuel Shutoff switch.
Edit:
If you can not hear the pumps run at all you do not need the fuel pressure gauge.
The pumps need to run for one second when you turn on the key with the engine not running. We need them to do this before we look at the fuel or the Ignition systems.
Old Sep 3, 2008 | 07:53 PM
foolforfords
the switch your refering to is the one on the fire wall under the drivers side, i was under the assumption that you only did that if the truck was in a wreck,its worth a try not sure how the reset works though .
Old Sep 3, 2008 | 07:59 PM
subford's Avatar
subford
It will also trip if you hit a hard bump sometimes or it gets kicked.
Just push down on the button on its top to reset it.
Old Sep 4, 2008 | 08:16 AM
guitarnik's Avatar
guitarnik
my truck did this one time and if i remember right it ended up being the "EEC" relay i think is what its called, it sits right next to your fuel pump relay under the hood.
Old Sep 4, 2008 | 02:44 PM
booman's Avatar
booman
Just went through this with my '91 F350 and it turned out to be the EEC. When it goes it can also take out the ignition module which sounds like it is not your case. The EEC for '91 is unique to '91 only whereas other years EEC covers several years models. Hard to track down the '91 EEC because of numerous part number changes.
ruger761
May 19, 2010 10:32 PM
lopitt85
Sep 1, 2009 08:54 PM
ms1780
Jun 22, 2009 04:36 PM
Byrddog
Apr 18, 2009 10:23 PM
BIGGUN338-378
Nov 23, 2004 03:00 PM
