VRV Testing Question
Old Sep 3, 2008 | 06:35 PM
Lead_Pusher's Avatar
Lead_Pusher
I found the directions to test the VRV. My question is do you have to have a seperate pump and gauge or can you use the combo kind that have the pump with the gauge in it link a vacuum bleeder? and if you can how do you hook it up. The instructions I have call for pump to top post and gauge to bottom post and help would be greatly appreciated thanks for the help
Old Sep 3, 2008 | 07:55 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I used a vacuum pump w/gauge AND a separate gauge when I did mine.. Worked like a charm!
Gary
Old Sep 4, 2008 | 06:24 AM
Lead_Pusher
EMD_Driver, Thanks for the information. I thought you might have to no to find the vacuum gauge. Thanks again.
Old Sep 5, 2008 | 07:54 PM
a711112a's Avatar
a711112a
what is a VRV????
Old Sep 5, 2008 | 08:04 PM
EMD_DRIVER's Avatar
EMD_DRIVER
It's a Vacuum Regulating Valve and it was used to control the vacuum to the modulator on the older transmissions. Since these diesels have a constant vacuum, it is needed to control shift points.
Electronically controlled transmissions don't use the vacuum.
Gary
Old Sep 5, 2008 | 08:32 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
That explains why I didn't know what it was!! Is the valve variable or is it either on or off.
Old Sep 5, 2008 | 08:35 PM
EMD_DRIVER's Avatar
EMD_DRIVER
It varies with the amount of throttle.. That's why it's mounted on the IP..
Gary
Old Sep 23, 2008 | 04:23 PM
Lead_Pusher
Well I adjusted the VRV from instructions I got from the diesel stop. I was alittle worried when I very first put the gauge on it was like 6 and 4. The instructions called for 13 and 7. I adjusted it and it went to 10 and 4 getting better. So then I just pushed it as far towards the cab as possible. And drum roll 13 and 7. The morales of the story the sun does shine on a dogs a$$ every once in a while
cabloom300
21
Apr 19, 2015 09:21 PM
zman1202
Jun 28, 2009 10:05 AM
murrhee
Jan 31, 2006 10:31 PM
mwk
Nov 18, 2005 08:22 AM
TdiRAcing
Dec 16, 2004 01:37 AM
