wire color code!!!
Old Nov 21, 1999 | 12:01 AM
Steve's Avatar
Steve
wire color code!!!
Just got a 1996 F250 and it has a two connector, 7-wire harness for towing. What is the color code? The previous owner took the pigtail so I am going to tap in to the harness and custom wire because I have to go to a slide in camper as well as the trailer plug. Thanks in advance.
Steve
Old Nov 22, 1999 | 10:37 AM
deleontow's Avatar
deleontow
wire color code!!!
Instead of cutting into wires, go to a local autoparts or uhaul and get the traier wire conector. It plugs straight into the current harness and gives you the wires already marked for about $20.00. This way you will not have problems later with poor contact or broken wires.
Dave
<a href="http://members.aol.com/deleontow/auto/index.htm">http://members.aol.com/deleontow/auto/index.htm</a>
Old Nov 22, 1999 | 02:41 PM
460 crewcab
Guest
Posts: n/a
wire color code!!!
You can get a plugin adapter for the 7 wire receptacle, it reduces the output to the 4 wire output. They are about ten bucks
Tim
Old Nov 25, 1999 | 10:41 AM
Trail_Rider's Avatar
Trail_Rider
wire color code!!!
svolpone
May 15, 2014 10:36 AM
swiss
2004 - 2008 F150
Feb 13, 2005 08:34 PM
Diesel Steve
Electrical Systems/Wiring
Sep 4, 2002 08:54 PM
Steve
Mar 1, 2000 01:21 PM
