64 Wiring Harness
Old May 13, 2014 | 10:54 AM
svolpone's Avatar
svolpone
64 Wiring Harness
I know I saw something on this before, but I can't find it.
Where is the best place to buy a wiring harness for a 64 F100?
Thanks in advance,
Steve
Old May 13, 2014 | 03:37 PM
resonateur's Avatar
resonateur
I was just searching the subject yesterday, and there were a few posts. One user referred to Mr.Mustang and had links showing, what appeared to be pretty nice looking original style wiring harnesses. If you do a search on this forum "original wiring harness", it should show up along with other suggestions. From what I have seen, most of the typical mid-60's truck parts vendors don't sell wiring harnesses for the 60's trucks, only the earlier models. I'll be interested to see what others post, as I'm in the market as well.
Old May 13, 2014 | 04:13 PM
TA455HO's Avatar
TA455HO
Lead Gopher
What are you after? Just functionality or also original appearance? One other option that I've heard good things about is
Narragansett Reproductions - Wiring Harnesses and antique car / automobile restoration supplies
Old May 14, 2014 | 02:08 PM
svolpone's Avatar
svolpone
Just functionality. This truck is too messed up to worry about making it stock.
Old May 14, 2014 | 02:18 PM
svolpone's Avatar
svolpone
Hey ND, is the 65 wiring harness the same as a 64?
svolpone's Avatar
svolpone
I called them. They haven't done a 64 yet, but they've done a 65.
Old May 14, 2014 | 04:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Depends...
Which loom are you asking about: main dash, tail light, generator, headlight, engine gauge feed?
If the dash loom: 1964 F100/250 2WD same as 1965 F100/250 2WD...except Camper Special.
If the engine gauge feed loom, you can splice in a 1965/66 Mustang loom (reproduced).
Taillight loom same as 1964/66 F100/250 2WD & 1966 F100 4WD Stylesides.
All the 1965/73 Mustang looms are reproduced. The dash loom cannot be used, but the others can be spliced in.
Old May 14, 2014 | 05:30 PM
svolpone's Avatar
svolpone
my problem is mostly the dash, so maybe this company's product may work for me. I'll do some research. ND, thanks for the info.
Old May 15, 2014 | 09:56 AM
daveengelson's Avatar
daveengelson
Have not found company that reproduces the dash harness; if intend adding more circuits then an aftermarket kit may be another option; otherwise, dash harness can be repaired but requires patience, I used plastic ties to keep the wiring trunks separate while making the repairs then the non adhesive harness tape to rewrap. I decided to go with the repro. harnesses, same wire color codes and connectors, matter of removing the old and install the new and added couple extra circuits.
Old May 15, 2014 | 10:01 AM
svolpone's Avatar
svolpone
Dave, hit that link above. they have it for a 65 F100. Give them a call. They seem to know what they are talking about (to me, anyways, but I'm easily fooled).
Old May 15, 2014 | 10:36 AM
daveengelson
Spoke with them about reproduction dash harness and they don't carry them but apparently if one sends them the original they can make one up, sounds promising, probably purchased the set from them if I were to have them make the dash harness?? Posting pic's of couple harnesses I purchased thru Mr. M for the 65.
**Headlight
http://i300.photobucket.com/albums/n...IMG_0005-2.jpg
**Taillight
http://i300.photobucket.com/albums/n...IMG_0002-6.jpg
Bigred1971
Mar 15, 2016 08:40 AM
bigdavesohc
13
Mar 6, 2011 10:21 AM
papa's 64
Mar 5, 2005 04:08 PM
red75
Electrical Systems/Wiring
Feb 26, 2004 09:47 AM
78f150custom
Jan 31, 2004 02:31 AM
