wiring help
Old Sep 2, 2008 | 06:54 PM
Kory717's Avatar
Kory717
wiring help
dose anybody know were i can find a 1974 f-100 390 engine wiring diagram? ive looked everywere and i cant find it any help would be great thanks
Old Sep 2, 2008 | 07:17 PM
saleen065's Avatar
saleen065
What wiring is it that you have an issue with?
Old Sep 2, 2008 | 07:23 PM
Kory717's Avatar
Kory717
im 16 and ive never done this before but im not sure how the coil is supposed to connect to the distributor and how its all supposed to get power
Old Sep 2, 2008 | 07:30 PM
saleen065's Avatar
saleen065
OK real easy here. You should have a three wire harness to the engine, One wire is the oil sending unit second wire is the water temperature sending unit and the third wire is the +12V that goes to the "bat" side of the coil. the - (negative) side of the coil goes to the single wire coming from the distributor.
To find out which of the three wires is what do the following:
for the +12V you will find that on a single wire, that will be for the coil
take the remaining two wires and ground one to the engine anywhere and see which gauge (water or oil) moves. Then you know what the last wire is for.
I hope this helps.
Old Sep 2, 2008 | 07:37 PM
fmc400's Avatar
fmc400
MSEE
Don't put +12V to the coil; you will burn it out. On both breaker-points and electronic ignition systems, the coil is powered through a resistor wire from the dash harness. This drops the coil voltage to 7-9V. The dash harness also uses a bypass wire to feed the coil directly to battery voltage during cranking, and through the resistive wire while the key is in run. It's not as simple as taking any hot-in-run wire and hooking it up to the coil.
The diagram below is for a Duraspark system. For a points system like your '74 has, the 'TACH' terminal of the coil (negative side) goes to the breaker points, instead of the Duraspark box. You can also ignore all the other Duraspark circuitry such as the pickup in the distributor.
I haven't credited the source of this image because it is so widely reproduced and distributed.
Old Sep 2, 2008 | 08:05 PM
saleen065's Avatar
saleen065
I stand corrected on the +12V feed to the coil. I forgot about the resistor inline for the wiring. But in general all my information is correct.
Old Sep 2, 2008 | 08:46 PM
Kory717's Avatar
Kory717
Thumbs up
thanks for the help guys
Old Jan 22, 2011 | 09:59 PM
Bigreyiii's Avatar
Bigreyiii
74 wiring diagram
I found a great diagram at fordification.net
Old Jan 22, 2011 | 11:28 PM
pittmick's Avatar
pittmick
I just put a new holley carb on and they sent a wire that was to be directly wired up for 12v stating the older ones were not 12v. However when I tested the line with the key on it read 12v. Are you saying that it will drop below 12v with the motor running?
Old Jan 22, 2011 | 11:40 PM
mikeo0o0o0's Avatar
mikeo0o0o0
What they are talking about is the wiring for the automatic choke. The original wiring for the factory carb receives its power from the stator terminal of the alternator. This is AC current not DC. If you put a voltmeter on it, it will read somewhere in the area of 7-9 volts. The aftermarket carb's. choke is designed to run on 12 volts DC. Several people here have reported running the factory wiring to the aftermarket carb without any problems.
meanv10
Modular V10 (6.8l)
Oct 15, 2009 01:12 PM
bgrdedf17
Wisconsin Chapter
Mar 10, 2008 07:02 PM
fordum
Nov 2, 2005 06:31 PM
hallecg
1997 - 2003 F150
Feb 29, 2004 10:20 PM
