I was looking at the cabs, and I found that the door on N series are not straight down. They have about a 45 degree angle, will this kill the deal for mer?
N series used their own special cab and doors. Look at the raised roof as well(on the later years). flashbacks f-100 parts. Look them up, he knows his 60s fords and may have a cab. Really good guy.
C1TZ8140300E .. Panel, Back of Cab / Fits 1961/66 F100/1100, 1961/66 N/NT/T500/1000 & 1967/69 N/NT/T500/1000. This is the entire rear body section that the back glass fits into.
C1TZ8102516A Right & C1TZ8102517A Left .. Windshield Post / Fits the same as above.
2many56's: If the roof was raised, this panel & the windshield posts would not be the same.
The 1970 and later L/LN Series is a completely different truck, sharing no body parts with the previous models. These do have a raised roof.
Kevin, if you had the 64/72 truck parts catalog, you would see the minor differences between the N & F Series cabs.
This is limited to the doors, because they have that notch in front, and some minor sheet metal parts...I'll call you and give you the differences, it's easier than typing *)(*(*&( part numbers.
