Driveshaft boot?
Old Sep 2, 2008 | 09:46 AM
txaggie96's Avatar
txaggie96
Driveshaft boot?
I need some help with the rubber boot on the driveshaft just past the carrier bearing, I think. It is torn and I need to replace it. Where do I get a new one? Does anyone have instructions on how to replace it? Besides the boot, what else do I need? Thanks for your help. Picture below, I hope. Sorry if it a little blurry.
Old Sep 2, 2008 | 10:58 AM
nhill2090's Avatar
nhill2090
you may be able to get somethign from Napa or Oreillys to work, like a boot for a CV joint, but other than that I doubt they would have it specifically for a driveshaft. Might check out your FOrd dealer if they are'nt too rediculous. You will also need the clips or some zip ties will do just fine.
It would probably be appropriate to grease the slip yoke while you are in there too.
Old Sep 2, 2008 | 11:57 AM
rebelchevy02's Avatar
rebelchevy02
The two metal rings there are what are holding it fast, a set of tin snips makes short work of them. I cant remember what that style is called, but usually auto parts stores can get that style. Usually in like a 20 pack. Looks to me like you may have greased it, then it pressurized the shaft, and finally blew out the boot? Thats exactly what I did, and how mine looks haha. I just didnt know I pressurized it, and thought for sure, that would not be air tight. Mines looked like that for about 60k miles. Best bet IMO would be a dealer, or a local driveshaft shop. Driveshaft shop being first choice if you have one.
Old Sep 2, 2008 | 11:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by txaggie96
I need some help with the rubber boot on the driveshaft just past the carrier bearing.
How about Ford Motor Company?
Here's the Ford part number and etc.
F81Z4421BA .. Driveshaft Boot & Clamp Assy
MSRP: $27.85 / FTE partsguy.com price: $20.05
Springer Pop (Marv) sent me an email and asked me to stop on by.
Old Sep 2, 2008 | 12:01 PM
nhill2090's Avatar
nhill2090
Looks like Bill has ya covered with everything you will need including price. Reps to you
Old Sep 2, 2008 | 12:13 PM
NumberDummy
Springer Pop (Marv) deserves the reps. He sent me an email, even gave me the parts basic number (4421), and asked me to help out.
Marv and I are in the SoCal Hawaii Chapter (my avatar is our chapter logo), and met at one of the chapter GTG's.
Old Sep 2, 2008 | 12:15 PM
nhill2090's Avatar
nhill2090
Don't thank me, thank Springer Pop (Marv). He sent me an email, even gave me the parts basic number (4421), and asked me to help out.
Regardless, you still helped contribute to the answer he was searchign for.
Old Sep 2, 2008 | 12:45 PM
brian42's Avatar
brian42
Veteran: Navy
Looks like you're covered for the boot.
I disconnect that section about once a year to grease the splines on the shaft. I suffer from the "clunk, clunk" when accelerating from a stop which is nothing more than keeping the splines of that shaft well greased. It's fairly simple to replace the boot.
Disconnect the shaft at the rear differential u-joint (and support). Disconnect the bracket around the carrier bearing (and support the shaft). Clip the straps holding the boot to the shafts. Pull really hard and separate the 2 shafts. Slide the replacement boot on one shaft, grease the splines (clean out all the old grease first), slide the shafts together and zip tie the boot to the shafts.
I do this about once a year and use a bunch of 2x4's laying around the house for support. After the first time you operate all the bolts and put anti-seize on them, it takes about an hour to do.
Hope this helps.
Old Sep 2, 2008 | 01:07 PM
txaggie96's Avatar
txaggie96
Thanks to all of you for the quick replies, especially with part numbers (Marv and Bill) and instructions on how to do it (brian42). You guys are really great. Now if I just had the time... While I'm thinking about it, should I replace the u-joint or anything else while I have the driveshaft loose?
Old Sep 3, 2008 | 06:13 PM
brian42's Avatar
brian42
Veteran: Navy
Not unless you think they're going bad. All I'd do is grease the splines.
wpnaes
Feb 4, 2021 11:00 PM
TexasGuy001
Feb 3, 2017 03:16 AM
TexasGuy001
Jan 16, 2017 07:02 PM
Doc Feel Good
Oct 6, 2011 12:47 PM
97F250LD
1997 - 2003 F150
Nov 21, 2005 05:29 PM
