Rear driveshaft slip yoke boot replacement
Old Jun 28, 2017 | 09:42 PM
wpnaes's Avatar
wpnaes
You may have seen the slip yoke lubrication 'how to' nestled in the rear pinion seal replacement 'how to'. https://www.ford-trucks.com/forums/1...l#post10449902.
It's also very well covered here.
My local parts store didn't carry this, but spicer makes a universal one that works fine. Your local driveline shop will likely have it. I paid $15.40.
1. Block all the tires, when you remove the driveshaft, the Ex will want to roll away.
2. Mark your tcase/driveshaft sections with a silver sharpie.
3. Get out your 12mm hex wrench and remove the 4 bolts that hold the front of the driveshaft to the transfer case.
4. It's heavy, so support it. Loosen the smaller end of the boot to remove the front stub-shaft from the longer drive shaft (still attached to the differential) to expose the splines.
5. Remove the old boot completely, attach the new boot to the stub-shaft. If you have the band tightener tool, use it, otherwise use pliers, needle nose or MacGyver zip ties.
6. Re-grease the slip joint. Inspect u-joints as needed. If your rear pinion is leaky, chop, chop, get on it!
7. Re-attach the stub-shaft to the long driveshaft on the truck, not forgetting to put on the smaller diameter steel band first. Make sure your sharpie marks line-up.
8. Re-attach the driveshaft to the Tcase flange using 4 12mm hex bolts. You may need to turn the flange a few degrees to match up the holes. Tighten per specs or 'nice 'n tight'.
9. Un block the vehicle before driving away.
Old Jun 28, 2017 | 09:58 PM
pirate4x4_camo's Avatar
pirate4x4_camo
its the little things that make the difference
Old Feb 3, 2021 | 02:15 PM
JBredensteiner's Avatar
JBredensteiner
3rd Gear
Thumbs up Thank you
Thank you for the write up. It helped, especially the part number for the boot.
Old Feb 4, 2021 | 11:00 PM
Ogre20012001's Avatar
Ogre20012001
Awesome
thank you for the write up.
Oldguyfl
Nov 26, 2025 03:03 AM
Stangfire
1997 - 2003 F150
31
Jun 28, 2015 09:06 AM
peganit2
May 30, 2009 03:06 PM
rmauch
1983 - 2012 Ranger & B-Series
Feb 17, 2004 10:21 PM
stangman67
Nov 11, 2003 05:35 PM
