Parking lights not working
Old Jul 18, 2000 | 04:45 PM
davetaylor's Avatar
davetaylor
Ive got a problem with my parking lights, If i pull the switch out halfway, the light will not come on but if I bring it out to the point just before the headlights come on and wiggle it around a bit to hit just the right spot they will come on. When I pull the switch all the way out to the point the heqdlights come on then the parking lights go back out.Ive done the tests with an ohm meter to test the switch and it seems to be just fine. Im quite stumped on this one.
Old Jul 18, 2000 | 09:36 PM
nitro94's Avatar
nitro94
It takes very little contact area for an ohms reading. Its entirely possible that it is not enough contact area to conduct current. With the information you have given I would have already installed a switch. Since you know which wires on the switch do what function you could check the circuit by jumping from the power supply terminal at the harness to the park light feed terminal and lights should be on.
Old Jul 19, 2000 | 03:28 PM
lostlen's Avatar
lostlen
steeleygreg
18
Feb 23, 2017 09:01 AM
Spparky82
Oct 20, 2015 05:55 PM
52' fordnut
Jul 21, 2015 10:07 PM
meck1
Feb 27, 2015 07:21 AM
Jasonf150
Nov 8, 2014 11:51 PM
