5.0 No start
Old Sep 1, 2008 | 02:00 PM
woodzracer's Avatar
woodzracer
5.0 No start
Hi all. I need a hand with my wife's '91 Cougar. It died the other day and after towing it home I checked and found no pressure at the shraeder valve. Replaced the pump, no change, replaced the relay. Now I have pressure at the valve(not sure how much just know I actually get a bunch of fuel out now. I'll get a guage tomorrow and check it) But still no start. replaced the regulator for fun. Still the same. I have good spark so it must be a fuel problem but where. filter is a year old. I checked the safety cut off switch in the trunk and its fine. Checked the PCM relay and it show no good but I'm not sure about that cause I'm gettintg power after the relay and if the relay was bad I wouldn't. Also Auto zone says they want $150.00 for that relay so I want to be sure. I pulled the codes and got a 181 (right side lean at part throttle) and a 332 ( egr valve not opening) Not sure if either of those would cause a no start. Any other Ideas? Thanks
Old Sep 12, 2008 | 11:36 AM
Boss50's Avatar
Boss50
Get a noid light and check to see if the injectors are pulsing. Very easy to do.
Old Sep 12, 2008 | 04:29 PM
woodzracer's Avatar
woodzracer
Checked the injectors, they were fine. I pulled the plugs and smelled fuel on them so I rechecked spark. Popped the distributor cap and found the rotor center contact had broken off and was laying across the rotor and firing the wrong hole. Just tuned this thing a couple months ago with some hi quality Auto Zone parts. Threw in a new rotor and she fired right up.
Old Sep 12, 2008 | 04:44 PM
doug1222556's Avatar
doug1222556
Originally Posted by woodzracer
hi quality Auto Zone parts. .
Talk about an oxymoron!
nomad27
Modular V10 (6.8l)
23
Mar 3, 2019 02:55 AM
jumbofordman
Feb 2, 2015 05:15 PM
outafaze
Oct 12, 2011 09:24 AM
dieselzen
Feb 9, 2011 01:24 AM
Beastybroncothe2nd
Nov 28, 2004 12:19 PM
