Fuel Pump Issue
Old Oct 11, 2011 | 07:26 PM
outafaze's Avatar
outafaze
Fuel Pump Issue
Guys, please confirm that my fuel pump is done. My wife's Navigator would not start the other night. After countless attempts, it started right before the tow truck driver loaded it. The truck drove home fine. Yesterday I cleaned the IAC valve (it wasn't too dirty) and connected a fuel pressure gauge to the shrader valve. Once again started after several tries. Pressure was ~35 psi at idle. Turned it off and it would not restart. Pressure indicates zero during cranking.
I swapped relay with the wiper relay, no change.
I've verified continuity all the way to the inertia switch, it was good.
I also installed a jumper across the relay terminals and still have no fuel pressure.
I'm pretty sure that the pump is toast, but have a couple questions:
1. Is there anything else I should check?
2. Is the fuel pump electrical connector accessible so I can verify the last part of wiring before I drop the tank?
Thank for your time and advice!
Old Oct 11, 2011 | 08:36 PM
kbsupercrew's Avatar
kbsupercrew
I would say your on the right track, im asuming you already tried using your spare key and determined it wasnt a dead key issue
Old Oct 12, 2011 | 12:32 AM
outafaze's Avatar
outafaze
I trieed the spare key this evening with no joy. looks I need to drop the fuel tank. Any tips?
Old Oct 12, 2011 | 09:24 AM
Donnie869's Avatar
Donnie869
Make sure it's as empty as you can get it. Makes it way easier, and take care when dropping to not break any hoses or lines. If you drop it slow you can disconnect a bit at a time. Goodluck.
chrisjb
Mar 22, 2014 07:06 PM
websthes
Sep 10, 2007 07:32 AM
GIXXED
1978 - 1996 Big Bronco
Apr 3, 2007 09:49 AM
Sitka
Modular V8 (4.6L, 5.4L)
Jan 13, 2005 10:03 PM
slammed96
1983 - 2012 Ranger & B-Series
Oct 7, 2003 09:26 PM
