1995 460 Cranks But Wont Start Replaced Fuel Pump . Pump Does Not Run For Few Seconds When Ign Turned On Flipped Relays Still No Pump Cross Relay Terms Pump Runs Still No Start In Path Of Hanna The Hurrican Help!
It is a little hard to understand what you are saying.
Check the INERTIA SWITCH behind the passengers kick panel (Behind RH cowl panel), push down on the button on top.
Also if this does not do it check the Fuel pump supply fuse and the PCM relay power fuse and also check for power on top of each side of each fuse with the key on.
Thanks For The Info. I Pulled The Battery And Tray To Check Fuseable Links, Wiring, Etc. All Ok. Replaced Battery It Started!! This Problem Started With A Low Battery When I Went To Start It Just Clicked.i Charged Battery Without Disconnecting It Then It Turned Over But Would Not Start. I Do Have A New Problem.i Have All Running&taillites,no Brake Lites Or Turn Sigs. I Do Have 4 Ways On Cab Only. Turn Sig Flasher Works But No Indicator Lites On Dash. Indicator Lites Work With 4 Ways
Sounds like you have a bad turn signal switch if all of the fuses (#1 & #5) are good at the interior panel fuse box (both fuses are 15A). The turn signal switch that does everything by the steering wheel. Ford calls this switch the Multi-Function Switch.
Thanks Again I Also Noticed Before The Lite Problem That The Cruise Would Shut Off When Changing Into The Left Lane On Hwy Could This Be The Same Problem?
Bad signal wiring/switch or bad tail bulbs can cause the cruise to shut off.
I have also heard of bad bulbs pulling down one of the circuits and making the cruise control shut off. This is probably related to the brake/turn circuit since the cruise uses the brake circuit to de-activate the cruise when you touch the brake.
