U-Joint
Old Aug 30, 2008 | 06:03 PM
John M T's Avatar
John M T
U-Joint
Hi all,
does anyone know the Torque spec for the U-Joint on a
99 f350 c.c. dually?
I have no zerks on there and was told that I should grease
'em up.
thanks
John M T
Old Aug 30, 2008 | 06:45 PM
danskool's Avatar
danskool
Go Bills !
Would this help you? It is for my truck but i would imagine it would be the same for yours.
Old Aug 30, 2008 | 06:57 PM
rebelchevy02's Avatar
rebelchevy02
If the joint does not have a zerk fitting, its a spicer non-greasable, do not try to grease it. They come already greased for a lifetime.
Old Aug 30, 2008 | 07:00 PM
danskool's Avatar
danskool
Go Bills !
I would just replace them with jerks instead of trying to grease them. They are cheap enough. Going to do all new ones this winter when my truck is parked for the winter months.
Old Aug 30, 2008 | 07:40 PM
SpringerPop's Avatar
SpringerPop
Besides, you can only grease half of it, at least easily.
Pop
Old Aug 30, 2008 | 07:46 PM
ron's power stroke's Avatar
ron's power stroke
Pop
lol just went though that today..only half a joint after i got coverd in grease lol...cute puppy Pop's
Old Aug 31, 2008 | 07:45 AM
John M T's Avatar
John M T
Thanks everyone,
what was suggested to me is to remove the drive shaft
and lube the splines,
supposed to be a maintenance thing.
has anyone heard of this, or done this?
thanks
John M T
Old Aug 31, 2008 | 07:49 AM
ron's power stroke
Originally Posted by John M T
Thanks everyone,
thanks
John M T
yes it is very good idea...just mark the shaft on both pieces so you can put it back together and stay balanced..some guy's here also drill and add a zerk so it can be greased without taking it apart...
Old Aug 31, 2008 | 08:52 AM
danskool's Avatar
danskool
Go Bills !
Here a manual blurp i put together a while ago.
IF it will help.
http://www.geocities.com/dirtsplat/DriveShaft.doc
Old Aug 31, 2008 | 12:38 PM
rebelchevy02
Yeap, Im one of those guys with a zerk fitting I put in there. Its very very important to put a small hole somewere in the boot, so you dont actually put pressure in there, because you will make it so the driveshaft will not be able to compress, it will force your pinion downward, and bind untill either a u joint breaks or it blows the boot out.
genscripter
Jan 29, 2013 11:42 PM
ford4her
13
Feb 22, 2009 02:07 AM
fordor
Oct 22, 2006 11:41 AM
Kalashtar
Jan 18, 2006 12:11 PM
Jag Red 54
May 28, 2004 10:22 AM
