Sponsored by: Real Truck
04 4R100 question
Old Aug 30, 2008 | 04:57 PM
suzuki0702's Avatar
suzuki0702
04 4R100 question
truck in signature is the problem. only issue im having is when i let off the gas in 3rd gear or maybe even overdrive, itll come out of lockup. then when i repress the accelerator, the rpms go up 250rpms then it relocks. fluid has been replaced every 25000 miles. truck has almost 60000 on it.
Old Aug 30, 2008 | 08:18 PM
aldridgec's Avatar
aldridgec
Normal operation unless this is something new that you noticed? AFAIK, that is how they are supposed to be on the gas motors. The diesel keeps it locked after a certain speed, but they (most manufacturers do this as well) do it on the gas ones to make it smoother and reduce the chuggle effect.
Old Aug 30, 2008 | 09:34 PM
Antelope V-10's Avatar
Antelope V-10
My 2003 does the same thing. Agravating isn't it. From what I can gather, tapping the brake takes it out of lock-up.
Old Aug 31, 2008 | 08:14 AM
suzuki0702's Avatar
suzuki0702
nice to know. it is annoying as all hell... i try to keep a steady pedal but everyone else likes driving with there brakes! thanks guys!
Old Aug 31, 2008 | 08:57 AM
dkf's Avatar
dkf
Custom tuning can fix that. TQ just don't wan't to stay locked, I agree its annoying and builds heat.
Old Aug 31, 2008 | 11:42 AM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
Dkf is right most custom tuning address’s this issue. Most people like converter to stay locked.
Some key things in a PCM that have an effect on a locked torque converter.
Throttle Position
Brake Input
Throttle Rate of movement In or Out
Time
Vehicle Speed
These are typical scalars in a PCM
Throttle Position to Not Unlock With Brake
Throttle Position to Open Converter at Closed Throttle
Throttle Rate to Unlock HiTP Tip In
Throttle Rate to Unlock HiTP Tip Out
Throttle Rate to Unlock LowTP Tip In
Throttle Rate to Unlock LowTP Tip Out
Time to Remain Unlocked After Brake Input
Vehicle speed Above to Remain Locked at Close Throttle
Old Sep 2, 2008 | 03:15 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yup, it is indeed normal - my 2001 V10 does it ... what I love is the extra kick of torque I get when the TC locks up again.
kjester
1997 - 2003 F150
23
Apr 2, 2013 02:52 AM
MrKen
Aerostar
Nov 9, 2010 10:03 PM
Chris Anchor
2009 - 2014 F150
13
Mar 30, 2010 09:33 PM
carpe_diem
4 Cylinder Engines
16
Jan 30, 2004 11:49 PM
liljase
Dec 11, 2003 10:38 PM
