1986 F150 idle problem
Old Dec 10, 2003 | 07:41 AM
liljase's Avatar
liljase
I have a 1986 F150 4X4 with a 5.0 fuel injected engine.Also has a overdrive auto trans.My problem is when the truck is in drive at a stop and you begin to accelerate the rpms drop before they raise.The truck has also stalled a couple times as a result of the rpms dropping too low.Also when you put the trans in drive before the gear engages the rpms rise slightly maybe 3-400 rpms.The trans doesn't bang or anything before going into gear and shifts smoothly.Thanks for any help.
Old Dec 11, 2003 | 10:38 PM
dashashopdog's Avatar
dashashopdog
sounds like a manifold vacuum leak. if it raises before it drops gear, than you might have some false air entering the manifold(vacuum leak). this will cause the motor to think it is sucking more than it is, cause the motor to overfuel, and die. Kurt
threewheelin
Jan 22, 2010 06:58 PM
OffRoadFord
1997 - 2003 F150
21
Jul 11, 2007 07:41 AM
ferchja
1997 - 2003 F150
Apr 19, 2005 12:53 PM
liljase
Dec 21, 2003 10:12 PM
