Sponsored by: Auxito
Starter wont disengage
Old Aug 30, 2008 | 02:21 PM
kjb304's Avatar
kjb304
I have a 2001 4X4 150 that is killing me. I have changed the battery, solenoid, ignition switch and starter all twice and checked the wires for continuity. My starter won't disengage. Any ideas?
Old Aug 31, 2008 | 07:53 PM
Ultramagdan's Avatar
Ultramagdan
Welcome to the forum!
I'm thinking it's in the ignition switch even though you have replaced it. Once you turn the key it sticks?
Old Aug 31, 2008 | 08:50 PM
2002 F350V10's Avatar
2002 F350V10
The starter not disengaging could be one of a few problems. Either electrical or mechanical. Either it is getting power when it should not, or the issue is mechanical. I have had it in the past(but not on a ford) where the drive teeth were too tight on the flywheel teeth making it not disengage, and I also had it where on a customers vehicle, I had 4 defective starters in a row, before I switched suppliers to get a good one. You need to do a better diagnosis.
m.collins
36
Apr 16, 2015 11:42 AM
CDaddy
Oct 10, 2010 08:17 AM
littledonko
Feb 11, 2010 11:11 AM
mmann246
1983 - 2012 Ranger & B-Series
Nov 10, 2007 11:13 AM
BigT_2000
1997 - 2003 F150
Aug 9, 2007 11:54 AM
