Lighting Mess
Old Sep 2, 2008 | 08:13 AM
subford's Avatar
subford
Here is the basic Turn-Stop circuit.
A 1983 Diagram for a F-series Truck.
Old Sep 2, 2008 | 06:05 PM
Franklin2's Avatar
Franklin2
I am going by a diagram from autozone's site, so see if these wire colors jive with what you have.
Put the turnsignal switch in the mid position. Push on the brake pedal. You should have 12 volts on a red/black coming into the switch.
With the switch still in the middle position, and the brake pedal pushed down, you should have voltage on the green and yellow/black wires. If you don't, the switch is bad.
mr56effie
May 8, 2014 09:29 PM
cbzdel
Mar 25, 2012 08:18 PM
79ford302
Apr 27, 2010 09:50 AM
boggerted
Sep 23, 2008 09:27 PM
slick78
Mar 17, 2002 07:06 PM
