C6 Vs E 40d?
And I think some of the 4WD models do get 20+ on the highway. If you plan to drive it a lot, I'd definitely go for an E4OD, or something better. For an occasional run to Home Depot or somesuch, tranny choice won't matter much. Personally, I'd probably go for a ZF if I had a choice.
A C6 in stock form will handle 500hp, add good clutches and steels and upgrade to one extra clutch per pack and your looking at a 700hp transmission and for under $1200 you can build one that will handle 1000+hp so don't give me it's an unreliable version of ANYTHING let alone a transmission that was designed by a guy that was high on pot, went to rehab got cleaned up and came back to develop the TH-350
*sigh* If ever there was a shining example why techs and shop owners avoid automotive web BBS like the plague - here we go! rather than READING what was actually typed....
I didnt say the trannys in question shared parts or were based on whatever.
How much I can build a tranny to handle is irrelevant and was not discussed.
The THM400 is perhaps the most bulletproof tranny EVER. The C6 is to ford what the 400 is to GM, 'cept the C6 was never quite as reliable - which is exactly what I said. Not only in cars and light trucks, but in coach building/chassis building applications the 400 got specced more than the C6 about 5:1
As for large 1990's electronics, no one alive is going to dispute that the 4L80E is stronger than the E4OD, and as for reliabilty...well the E4 reputation is easily googleable and speaks for itself - which is exactly what I said.
Which, shockingly is what I told the original poster: choose the C6 over the E4 for both reliability AND price. 'magine that!
PS: the C6 handles about 350HP in stock form, but thats ok, it takes about 100hp to turn it. the CASE can handle about 500/500. its pretty embarassing when your tranny splits in two at the strip so the early cases are actually in almost as much demand as the variable stator 400's (but this could also be due to the fact that the DRCE engine block is GM based)
Now, if you will excuse me, I need to go throw away some clutch packs and gearsets from the parts shed 'cuz I have never seen them. I for one am tired of tripping over stuff I have never seen.
If you take a look around you will find many builders that can build and in fact HAVE built and are running C6 trans behind 2000hp blown big blocks (you might want to take your "the case only holds 500hp" and tell that to Bob Chandler (for those that don't know he is the owner of Big Foot) that motor puts out depending on the venue they are running 1500-2500hp and yes he has a C6 behind it, or how about the Big Dog monster truck 1500hp blown big block running once again a C6.
As to the 400 being spec in motor home chassis more then C6 you are wrong once again and the choice had ZERO to do with the transmission. IT has to do with what frame they bought and for your information there are many thousands of ford C6s in motor homes ambulances tow trucks etc.
As to the 400 being SSSOOOO much stronger, ever wonder why all the GM guys use a TH350 for racing (except those that can afford to upgrade a PG) well I would tell you but it would go over your head. The 400 had a lot of design issues. The 400 is an ok transmission but even GM didn't use it in their high performance vehicles what a concept. (and for your information I was Chevrolet certified journyman level tech on this stuff as well as ATRA and ASE master tech)
Xtra clutches, roller bearings, lower gear sets, basically everything but a 300M shaft. For way less than what my E40D will cost to rebuild.
If I could control the lock up in 3rd and 4th I would like my E40D. I just do not have the time to tinker with it.
My vote is C6.
Monsterbaby is right, many C6 in high HP situations.
QuadDriver .... it is not our fault you probably let the bellhousing bolts get loose or something.... Even if you did not, their are failures in every scenario.
People are just plain misinformed and uneducated about the C6.
*=not entirely true, if memory serves the cat 2+2 had a PG available until 1970
The reality is, you spoke up without READING MY POST and now you are just thrashing with drift of epidemic proportions. thrash some more if you need to. But each time you post nuggets like
my answer to the poster (which as you note no one has actually disputed) - stands.
You stated, and I quote
blasphemous
__________________________________________________ _________________________
(adj) blasphemous, profane, sacrilegious (grossly irreverent toward what is held to be sacred)
A definition of sacred on the Web: worthy of respect or dedication
I restate: (in bold type so maybe it will sink in this time)
I used to buy light trucks for outrageous towing requirements and never worried about a C6.
(I) Never, repeat NEVER had a problem with a C6 when it was maintained and driven properly.
... slippage is indeed one of the reasons the mileage isn't that good, however reliability was NEVER a problem when a C6 was used and maintained properly.
You, quaddriver, might even want to re-read my whole post if you still have doubts that someone actually disputed the advice you presented.
Time to get out the pitchforks and torchs boys!!!
We got us a heretic .....
Ford never built a 365 to 400hp motor? guess you don't consider the 365hp Police interceptor 390s used from 67-71 with C6s behind them as ford motors then.
AND YOU are the one that claimed the cases would split at 500hp so when I brought up all the 2000hp motors in front of C6s your response is it's illrelevent. I have a real good suggestion for you don't ever post about transmissions again and NEVER work on one. I am not even going to dignify the rest of your post with an answer because everyone in this thread can see through it.
Please note, you want everyone to beleive the C6 is strong (which oddly, I never said it WASNT in any post in any form) and as evidence, you offer up your own C6 which is by your admission, heavily modified to make it strong.
ummmm ok....
