4x4 Front wheel bearings
I've been searching the forum for quite some time this afternoon. I have a grinding up front and i'm assuming it's the wheel bearings. All i've read about is the problem with the hubs on the 98-00 rangers. I have a 98. The 4x4 works fine. Parts store is telling my i have to replace the whole hub and cannot just replace bearings because the hubs are sealed. Is there anyway around this where i can disassemble the hub to replace bearings. I just traded for this truck and it is my first ranger. I love the truck. As i said before it is a 98, it is 4x4 ext cab with the 4.0. Any advice or tips will be appreciated.
Thanks
Keith
Thanks
Keith
I just wanted to add that this forum is outstanding. I traded my 93 f-250 4x4 (gas guzzler) for my current ranger and a katana 750. Any way i had great help with my former truck when the speedo went crazy and it started to stall. It was reccomended that the vss was bad and that's what it was. I was reading the sticky's again and there was one pertaining to a problem i have with the ranger that has been bothering me which is the clunk (or something to that nature..almost feels like slack in the drivetrain). I read that is a common problem that is usually fixed by dropping and cleaning-greasing the yolk. That is great news because i thought it might be something in the diff. Enough brown nosing, but there is a wealth of info on this board.
Thanks guys. Going manual is something i've been thinking about. I found the place that sells them by searching the forum. For the pair they are only around $150. Is there anything i need to do for the swap other than maybe plugging the vac lines. If someone knows of a write up that would be awesome.
The only manual "hubs" available for the PVH Ranger are made by AVM and they are more akin to lock/unlock conversion pieces. They are not the same thing as the integral hub/bearing assembly. So if it's a bearing issue causing the noise, then you are still going to need the hub/bearing unit for that side.
airsoft1779
28
12-12-2012 10:09 PM
davidstjohn1
1983 - 2012 Ranger & B-Series
02-20-2010 09:22 PM
