port match throttlebody-intake?
Old Aug 27, 2008 | 04:28 PM
jerg_064's Avatar
jerg_064
I'm putting some thumper heads, a cam, maf, and gt40 intake in my 91'. The lower will be port matched to the heads.
The throttle body is 65mm, and the intake opening is 70mm, would there be any gain in port matching them.
I was thinking that if the air goes from that smaller volume tube to a larger volume opening that it might cause a loss in velocity, And a lil turbulence which would cause the air to flow even worse. Would I be right in that assumption, as far a physics go anyways?
Old Aug 27, 2008 | 04:48 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Is there a 70mm tb you could use instead?
Matching it wouldn't hurt, but I can't see that it would help all that much either. A little turbulence but not enough to affect flow. There a long way for air to go from the tb to the intake valve...
Old Aug 27, 2008 | 05:57 PM
jerg_064's Avatar
jerg_064
I'm sure simply buying a 70mm would probably be easier.
I basically just wanted to know if my theory was correct, I was doubting that it would really affect the efficiency of the engine. Thanks for the info.
Old Aug 27, 2008 | 09:01 PM
Blurry94's Avatar
Blurry94
You wouldn't notice any difference.
broke77f100
Bronco II
Jun 24, 2008 09:51 AM
flareside_thunder
May 25, 2008 11:42 AM
jamies460
May 12, 2008 09:41 AM
JOHNNEHUS
Jul 21, 2007 11:58 AM
phoneman91
13
Oct 30, 2006 06:12 PM
