which clutch is right?
Old Aug 27, 2008 | 04:14 PM
FLN's Avatar
FLN
68 F100 with 390.what is the correct clutch size for this truck? right now its got a 10 inch clutch which bolted right up to flywheel, but have had chatter problems in reverse.i want to fix this issue & have been told its the wrong size clutch. been told a 10, 11, 11.5 and a 12 inch is the right fit. which is it?and will they still bolt to same flywheel. somebody state the right facts for this stump puller! also have been looking at the hays clutch kits .anybody had luck with these.the kits from auto zone are garbage.
Old Aug 27, 2008 | 07:30 PM
BobbyFord's Avatar
BobbyFord
I had a 12" clutch in a '72 390 truck that I sold. In fact, I have a brand new 12" pressure plate, disc and T.O. bearing in my garage for the truck that I sold. Shipping would be a killer.
Old Aug 28, 2008 | 10:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
10" clutch? What the heck flywheel do you have?
Since when will a 10" clutch fit an FE flywheel?
There are only two FE flywheels used from 1965 thru 1976 on 352/360's & 390's.
390: C5AZ-6375-L / Marked: C5AE-6380-K / Uses an 11 1/2" clutch on a 12 7/8" bolt circle.
352/360: C5AZ-6375-K / Marked: C5AE-6380-J / Uses an 11" clutch on a 12 3/8" bolt circle.
Both flywheel's ring gears have 184 teeth.
Old Aug 28, 2008 | 02:46 PM
BobbyFord's Avatar
BobbyFord
There's a bunch of clutches out there that all have the same bolt circle, but have different diameter discs and pressure plate surfaces.
Old Aug 28, 2008 | 03:54 PM
NumberDummy
Gypo's: I kinda figured that, but who in the world would want to use a 10" clutch with an FE engine? In-adequate is not the word for it.
Old Aug 30, 2008 | 08:10 PM
Dave Severson's Avatar
Dave Severson
Hays is an ok clutch....IMO not the best... I've had really good performance out of the McCleod clutch and pressure plates. Clutch selection has a lot to do with what you are using the truck for, how much horsepower and torque your putting out, and how much $$$$$ your willing to part with... Ram is also a good street type clutch, ran one in an FE powerd Mustang and was very pleased with it.... Both Ram and McCleod have very knowledgeable and helpful techs on their tech lines.....
Old Aug 31, 2008 | 10:28 AM
Dusto5's Avatar
Dusto5
Geeze the clutches for these are friggin' pricey! Napa's is $200, Checker wants $320, a Centerforce is $420. LMC carries two kinds, one for $200, and one for $240. I don't know what the brands are other than the Centerforce, but I would hope that ALL of them are made in the USA, otherwise I'd find it pretty much outrageous if they came from overseas or Meheco.
Old Aug 31, 2008 | 07:41 PM
Dave Severson
Not a bad price by today's standards...The McCleod Soft-Lok going in my Ranchero is a tad over $1600.00, it's an update of the old Ram dual disc that runs about $1100.00....Quality doesn't come cheap and as you add horsepower the $$$$$ requirements for the driveline parts gets higher, too....
Old Aug 31, 2008 | 08:24 PM
ford390gashog's Avatar
ford390gashog
My guess is that the clutch you have now is not a 10'' clutch. Its a 11'' for a 360/352 engine. You need a 11.5'' clutch and flywheel.
You need part # 747 and part number MU10111 Online Auto Parts and Auto Accessories Store at PartsAmerica.com
For under 250.00 you can get a new flywheel and complete clutch set.
Old Sep 1, 2008 | 08:14 AM
Dave Severson
For stock or mild engine, looks like one heck of a good deal!!! Even has a decent warranty....
86pullerf350
20
Mar 18, 2016 10:49 AM
Andy_F100
Sep 15, 2015 05:46 PM
FordOwnerJoey
Oct 5, 2013 07:34 PM
1982fordf100
May 30, 2006 07:08 AM
paulbunyan22041
Apr 2, 2004 07:26 PM
