A/C Q's
Old Aug 27, 2008 | 10:44 AM
03_PSD's Avatar
03_PSD
A/C Q's
Anyone know what could cause the A/C to not cool as well under moderate to heavy throttle. My A/C has just started doing this, under acceleration it will blow out warmer air and when sitting still or cruising it will blow cold air. Could it be low on freon?
Old Aug 27, 2008 | 10:53 AM
joegebff's Avatar
joegebff
Gone Fishin for Mark
The compressor will kick off at WOT. Does not sound like low freon. Does it keep blowing at the same velocity?
Old Aug 27, 2008 | 10:56 AM
03_PSD's Avatar
03_PSD
yeah, it blow's the same no matter what. what worries me is when driving normal it'll do this when pulling a moderate hill, not at WOT. it has just started doing this.
Old Aug 27, 2008 | 01:53 PM
joegebff's Avatar
joegebff
Im not sure of the problem. It seems that for some reason the PCM is telling it to disengage. You might do a search for A/C clutch 'air gap'.
If it gets too hot, just go fishin......
Bump!
Old Aug 27, 2008 | 02:00 PM
RckyMntnKng's Avatar
RckyMntnKng
Yeah you might want to check the gap in the Air clutch...Sounds like it may be getting worn long.
Its an easy fix....The gap needs to be around .035. Pull the 1 bolt in front of the compressor and get a washer off the shaft to bring it back in range when re-installed.
Old Aug 27, 2008 | 02:03 PM
03_PSD's Avatar
03_PSD
Thanks for the tip.
I'm deffinately doing some fishing today!!
Old Aug 27, 2008 | 02:11 PM
03_PSD's Avatar
03_PSD
Thanks for the tip guys, i did a search and found that article that Springerpop wrote. I'm going to give it a whirl today!
Old Aug 27, 2008 | 02:27 PM
empiretc's Avatar
empiretc
yeah, check the gap first. if that doesn't cure it, get a good set of gauges and check the freon level.
mine did that, and i ended up putting in a complete new system. f**ds are notorious for that.
Old Aug 27, 2008 | 03:41 PM
Ponyboychris's Avatar
Ponyboychris
I had the same issue on my old PSD, did SpringerPop's fix and it solved the problem. This was after I did a freon change...
Old Aug 27, 2008 | 03:43 PM
03_PSD's Avatar
03_PSD
I'll do the fix tonight and let you guys know what it did for me, hopefully fix it!
Old Aug 27, 2008 | 08:17 PM
greg_23805's Avatar
greg_23805
I'd check the freon charge first with a set of gauges. I have an '02 and I have never been able to run in Max A/C on the highway. I've worked on a/c and refrigeration for years and did a lot of tests. When the rpm on my truck is above 1500 and the cab temp is at about 78 degrees, the low pressure side goes to 23psi which is at the cutout point for the low pressure cutout switch.
That low press cutout switch is there to protect the system from freezing. When you get your gauges you'll see that 23 psi is about 30 degrees F iirc. I just didn't feel like messin' with it so left it like that for years. I now see some clues after running for years that the accumulator may be the culprit. I'm going to change it out soon and see if I can finally run on Max a/c without the compressor cutting out when on the highway or above 1500 rpm. It really does suck to not be able to use Max a/c, well, I could use it but what's the use, it doesn't cool the truck down any better then Normal setting because in Normal setting, the compressor will keep running because the fan is sucking in outside warmer air and this keeps the low pressure side higher.
Anyhow, your symptoms are the same as mine, let us know what you find out.
Old Oct 2, 2008 | 01:59 PM
03_PSD's Avatar
03_PSD
update - sorry for so long, been busy, but took one of the gap spacers out and the a/c's blowing ice cold all the time now!!
Thanks everyone!
deathinc_7
Modular V10 (6.8l)
Aug 19, 2012 09:13 PM
race39
Mar 29, 2012 11:59 PM
sportsmansteve
Jul 20, 2011 10:28 PM
twg1966
Escape & Escape Hybrid
Jun 19, 2011 12:16 AM
918eva
May 24, 2010 09:16 AM
