Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Mariner A/C
Old Jun 17, 2011 | 04:52 PM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
Mariner A/C
Question for everyone: Under heavy acceleration or at highway speeds, the a/c doesn't blow cold air. When you drop off the accelerator the cold air returns. What could be causing this issue?
Ted
Old Jun 17, 2011 | 09:03 PM
projectSHO89's Avatar
projectSHO89
Depending on the year, it's probably normal (under the control of the PCM to free up horsepower for acceleration). Check your owner's manual.
Old Jun 17, 2011 | 09:23 PM
wptski's Avatar
wptski
Normal under WOT.
Old Jun 18, 2011 | 11:14 AM
twg1966's Avatar
twg1966
Sorry, I forgot to post the year. It is a 2005 and we had this problem shortly after purchasing, then it seemed to disappear and now it is back. I will continue to monitor it and see if it continues.
Old Jun 18, 2011 | 06:12 PM
projectSHO89
While you're at it, check the clutch air gap. An excessive gap can allow the clutch to slip under high-load conditions. If the gap is over .035", perform a shimectomy.
Old Jun 19, 2011 | 12:16 AM
Torky2's Avatar
Torky2
Originally Posted by twg1966
..... When you drop off the accelerator the cold air returns. What could be causing this issue?
Are you sure the cold air is really going away, or is it being redirected to the defroster vents? Get on the highway and duplicate it, and when it appears to go away, put your fingers up into the defroster vents.
Our trusty Grand Caravan, the predecessor to our Escape, developed that over the years. Going up a hill on the interstate, after a little bit the airflow would shift to the defroster vents (the safety default). I looked all over for vacuum leaks, which are usually the problem on Ford vehicles with vacuum-controlled air direction, but found none. The one-way check valve to keep vacuum in the vac reservoir in high engine load conditions (wider opening of throttle - low intake vacuum) seemed to work ok each time I tested it. Finally pulled out the check valve once, and had it pass air both ways for an instant, then okay. I replaced the check valve, that fixed the problem.
I'm assuming your year's would have vacuum controls, but I don't know for sure.
wgm114
Aug 12, 2012 09:24 PM
wgm114
Aug 6, 2012 06:04 AM
race39
Mar 29, 2012 11:59 PM
03_PSD
Oct 2, 2008 01:59 PM
murrman
Dec 19, 2000 03:39 PM
